Newbies Gsr
Whats up. Like the title says im a newbie and this is my Gsr, it is a work in progress. Tell me what you think. No the interior is not finished yet but not much is going back in.
Thanks purple gsr
Modified by k279 at 1:23 AM 2/12/2004
Modified by k279 at 1:25 AM 2/12/2004
Modified by k279 at 1:29 AM 2/12/2004
Thanks purple gsr
My friend is a rally car cage builder and another friend was on the realtime integra team as a mechanic/pit crew for 4 years so between the two it was a custom built cage, and no no engine shots yet. The engine is pretty stock other than a jdm mugen header, nsx intake,test pipe and magnaflow exhaust. Yes it is kind of a daily driver other than I have a work van so it doesnt need to be comfortable for a daily commute.
I love the interior, but I think you should go black. The wheels are a bit much, I'd drop down to a good set of 16's at the most. And I'd add an ITR front lip. I love the cage though.
Welcome to Honda-Tech by the way.
The wheels have been my debate. Im not sure if I should sell the kosei's and get a smaller set or sell my blades and get a track only set. Or if I should just put race or autocross tires on the blades.
Well the cage is alright I guess. It would be better if there were a bar going straight across a little higher up than that bottom one in back at the bottom of the big X. Ideally racing harness shoulder straps should be parallel to ground, and you would need a bar a little higher to acheive that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k279 »</TD></TR><TR><TD CLASS="quote">The wheels have been my debate. Im not sure if I should sell the kosei's and get a smaller set or sell my blades and get a track only set. Or if I should just put race or autocross tires on the blades.
Yeah the Kosei's probably have to go......the roll cage is mean!
</TD></TR></TABLE>Yeah the Kosei's probably have to go......the roll cage is mean!
Actually the bar in the back is to stiffen up the rear chassis and can be used for a harness bar although not ideal.It also elimintates a rear strut tower bar sicince it is tied in with the suspension mounts. Vtech fool- ive been at two meets in the last month , one at alki and one at applebees so youre proboably right.I have painted all the floors in a black nonskid paint scince then.
Thanks for the feed back
