Newbie needs help...
Trying to take out climate conrtol panel to swap with ITR and having problems. I have tried doing a search and following their directions but seem to get stuck after everything is out except for the panel itself. Someone said to disconnect the "green" wire...I don't see that. I see an aluminum bar/cable thing that is connected to the temp control. I'm not too mechanically inclined when it come to dealing with small plastic interior pieces. If someone has pics or better detailed instructions it would help me out a lot. Also haven't tackled it yet but how do you swap out the clock? Buying a JDM GS-R clock...it it amber right? Thanks for all the help.
[Modified by FD3S, 9:31 AM 5/18/2002]
[Modified by FD3S, 9:32 AM 5/18/2002]
i've taken out my climate control like 4 times cause one of my dumb *** friends broke my switch.
1. pop out the hazards and defrost button and disconnect the harnesses
2. i think there are 2 screws that you need to take out behind it
3. Pull out on the climate control and the clips should pop out
4. Reach your hands back behind it and disconnect the green harness and disconnect all the connectors w/ harnesses
5. there's a little white clip underneath where the temp cable is connected
6. Twist that clip and a small metal piece, the white clip, and the cable will all fall apart
7. Then there is a piece that holds the cable onto the climate control...try to get the cable out w/o breaking the small piece thats holding it
8. If your having trouble...go look underneath the passenger side dash and you'll see a cable connected to a latch...that latch is to go from warm to cold. Just slide the cable off
9. Thats it...good luck
LSegHatchy
Aug 4, 2004 06:45 PM
