Neutral / starter switch Help
Old Mar 24, 2009 | 11:25 AM
Gregg00R's Avatar
Icon2 Neutral / starter switch Help
Whats going on everyone just recently did an auto to standard swap on my 98 integra. I've been trying to figure out how to wire up this switch so i have to push the clutch in to the start the car.. If anyone could help me out It would be greatly appreciated thanks
Also I already have the switch just need to know the wire scheme
Old Mar 25, 2009 | 09:33 AM
sitinduk's Avatar
Default Re: Neutral / starter switch Help
I did this on a '95. I think it's the same on later years.
Connect one terminal of clutch interlock switch to ground.
Find the heavy gauge wires Blk/Red & Blk/Wht (not 100% sure of colors) in the A/T Gear Position Switch.
Get a auto relay and wire it as follows:
85 -> 2nd terminal of clutch interlock switch
87 & 86 -> Blk/Wht of A/T Gear Position Switch
30 -> Blk/Red of A/T Gear Position Switch
The idea is that Blk/Wht and Blk/Red are only connected when the clutch pedal is pushed in.
This is the info I followed, except I thought it was better to use a relay:
http://www.team-integra.net/forum/di...urnPage=Search
Old Mar 25, 2009 | 09:24 PM
Gregg00R's Avatar
Thanks a lot sit, was looking all over for this info. Everything worked out good on your 95' ??
Old Mar 30, 2009 | 05:08 AM
sitinduk's Avatar
Yea, I'm up & running for 1 1/2 yrs now.
I've been through three clutch master cylinders so far, but that was a separate issue.
First one was used from a junk yard -> started leaking at the pedal.
Second one I got off of ebay -> also leaked.
Third was a new one from Acura -> held up for 1 yr now.
Old Mar 30, 2009 | 06:38 AM
jrthestar's Avatar
why would you wanna wire up that switch just so u can push the clutch in to start the car? i left mines without it you need the dashboard harness from a manual integra.. so i just left mines as it and wired up everything else.only issue im having is idle being retarted
Old Mar 30, 2009 | 08:19 AM
sitinduk's Avatar
It's just for safety, especially if other people will be driving the car so they don't accidentally start it in gear.
If you do want to bypass it, just connect Blk/Wht and Blk/Red wires from the A/T Gear Position Switch harness together. Just remember not to park it gear.
Makoa_13
Jan 26, 2019 10:31 AM
josh352727
Aug 19, 2011 08:54 AM
rolledthatho
35
Sep 1, 2005 08:02 AM
Toptul_Honda
Jan 26, 2003 08:53 AM
