Neuspeed upper tie bars?
Old Jan 6, 2003 | 03:20 PM
Racer X's Avatar
Default Neuspeed upper tie bars?
If anyone has seen the neuspeed front upper tie bars, can you tell me why there is two different styles? One looks like a single bar and the other has split ends. Didn't know if it's just a difference in styles or if one is better than the other.
[Modified by Racer X, 6:21 PM 1/6/2003]
Old Jan 6, 2003 | 03:42 PM
SonicGSR's Avatar
Default Re: Neuspeed upper tie bars? (Racer X)
Its one piece
4 mounting points
The NEUSPEED Upper Front Strut Tie-Bar is a must for all cars from street to all-out competition. The NEUSPEED bar takes the roll and twist out of the sheet-metal frame – an inherently weak spot. Unlike hinged, single-bolt designs which flex and pivot, the NEUSPEED bar's solid mounting is very rigid, making steering quicker and more responsive to your touch. You will feel the difference in handling! This bar is especially important if you change to larger tires. Our lightweight twin-tube design easily bolts to the strut towers, a strong point on each side of the body, to provide maximum performance with the greatest strength. All NEUSPEED bars are made from heavy-wall, 3/4-inch and 7/8-inch diameter steel tubing ('98 Accord, Golf IV and Jetta IV use 1'' tubing) aircraft heliarc welded to 1/4-inch steel mounting plates, and feature a wet-look gloss black powder-coat finish. We now offer polished NEUSPEED upper strut tie-bars. These new bars are chrome plated to a mirror finish. NEUSPEED bars install in minutes on most applications by bolting to the factory strut/tower retaining studs or bolts. Some VW applications may require drilling four holes by marking the self-aligned Strut Tie-Bar and installing special aircraft threaded Nutserts® with the tool provided. Each Nutsert withstands over 800-lbs pull and provides the greatest strength to tie in the front body panels. NEUSPEED Strut Tie-Bars fit with all standard factory equipment, and all service work is performed in the normal manner.NEUSPEED was the first... and is by far the best strut tie-bar on the market.
Old Jan 6, 2003 | 03:46 PM
Racer X's Avatar
Default Re: Neuspeed upper tie bars? (SonicGSR)
I've read this before but there is another tie bar that is different.
http://www.groupbuycenter.com/buy.aspx?id=7989
if you scroll down there is a picture of two different bars. Any benefit between the two?
Old Jan 6, 2003 | 03:59 PM
SonicGSR's Avatar
The difference between this and the one posted in my first reply?
I think this is a newer design for neuspeed, It looks like a ITR clone to me.
It bolts up using the smaller bolts on top of where your shocks are.
I dont have a pic of how the first one mounts to the Integra.
This is the bar i have on my car and I Like it. Feels Great, the construction is nice, and I belive I picked it up for around $80.00 US
I'm sure you can't go wrong with either, neuspeed makes some very good Bars
I would recommend the one with the 4 mounting points.
[Modified by SonicGSR, 5:03 PM 1/6/2003]
Old Jan 6, 2003 | 09:32 PM
Windows 95's Avatar
Yes, this is Neuspeed's latest strut tower bar. ITR clone indeed.
Depending on your application, the "4 point" neuspeed bar will mount differently. On my friends G2 integra, the bar mounts to the shock tower bolts(all 4), so its really like any other decent strut tower bar.
On my friends EG and my 97 GSR however, the bar does NOT mount on the strut towers, but rather the 4 A-arm mounts. Very unique design, but IMO, it won't make a big difference in either bar you get. Neuspeed makes high quality products, I highly doubt either bar is "better," both are great! I just got the 4 point b/c it was different.
Old Jan 6, 2003 | 09:36 PM
gandhisan's Avatar
Default Re: Neuspeed upper tie bars? (Windows 95)
Id take the 4pt mainly because it seems to be one piece. That is always a plus in my books
jdmstylesi
18
Sep 27, 2006 07:54 PM
halcyon026
Honda Civic (2001 - 2005)
Mar 30, 2006 05:04 PM
kenjief8
Dec 30, 2004 06:59 AM
M-EJ1
May 9, 2002 10:00 PM
