Need timing help fast
Old Feb 12, 2012 | 03:19 PM
brad22486's Avatar
Default Need timing help fast
Changing timing belt b18b need to know how to set timing please help fast thanks
Old Feb 12, 2012 | 03:26 PM
Dc4LsTeG's Avatar
EK9
Default Re: Need timing help fast
Have you searched? You don't have a Haynes manual?
Old Feb 12, 2012 | 03:44 PM
brad22486's Avatar
Yea have searched and no haynes
Old Feb 12, 2012 | 04:01 PM
TheRealTegger's Avatar
You must have the belt off already...
Engine MUST be at TDC #1 cyl compression.
Crank pulley mark lined up with mark on oil-pump.
Cam pulleys with "UP" marks facing up. There are marks on the cam pulleys that will now point towards each other. Get them perfectly in alignment.
Put drill bits into the holes in the fronts of the camshafts.
Now try and get the belt on with the cam pulley marks still perfect. It is NOT easy to do without ending up with one cam off by a tooth.
If the old belt is still on, use Wite-Out to make marks on the pulleys and crank, and on the belt where it meets those items. Slide old belt off. Transfer marks to new belt and install. Piece of cake.
Old Feb 13, 2012 | 05:32 AM
brad22486's Avatar
K thanks
gravity73
Feb 9, 2014 03:05 PM
giovannie23
Aug 9, 2013 08:30 PM
7andaswitchblade
Jun 1, 2007 01:46 PM
Seedc2
Mar 22, 2005 04:53 PM
SHG_EasyE
Mar 9, 2005 10:10 AM
