Need timing help fast
Changing timing belt b18b need to know how to set timing please help fast thanks
Re: Need timing help fast
Have you searched? You don't have a Haynes manual?
Yea have searched and no haynes
Originally Posted by brad22486
(Post 46849218)
Engine MUST be at TDC #1 cyl compression. Crank pulley mark lined up with mark on oil-pump. Cam pulleys with "UP" marks facing up. There are marks on the cam pulleys that will now point towards each other. Get them perfectly in alignment. Put drill bits into the holes in the fronts of the camshafts. Now try and get the belt on with the cam pulley marks still perfect. It is NOT easy to do without ending up with one cam off by a tooth. If the old belt is still on, use Wite-Out to make marks on the pulleys and crank, and on the belt where it meets those items. Slide old belt off. Transfer marks to new belt and install. Piece of cake. |
K thanks
