need tech info and suggestions on ls/vtec conversion
I have a 92 ls teg and i would like some info or suggestions on what i will need and exactly what i have to do to make sure the conversion is successful. Right now i am planning on putting a b16a head, IM, ECU. Please let me know if i need anything else or if you dissagree and what you suggest. Precieate it!!!
[Modified by Project LSVTEC, 2:02 PM 11/11/2001]
hey... now im thinking if i would be better off with a swap of a b16 motor instead of the lsvtec conversion. please help!!!!!!!!
for a ls-vtec to run right
b16 oil pump
b16 distributor
b16 cams
b16 ecu or b181/5
for a motor like yours with that many miles
i sugguest new bearings and rings if possible
not oem rings either get some after market ones
with out the new bearings your motor won't last for more than 6 months
a b16 swap into your integra?
thats a waste of time and money
you'll get your moneys worth with the ls-vtec conversion
b16 oil pump
b16 distributor
b16 cams
b16 ecu or b181/5
