In need of some advice!
Old Mar 7, 2017 | 06:58 PM
jkeokham's Avatar
Default In need of some advice!
Hey everyone,
Just wanted to know if anyone can help pinpoint whats exactly wrong with my car. So about 75% of the time my 1996 integra GSR drives fine, except that the input shaft bearing on my transmission went bad and makes a bunch of noise when I let go of the clutch. At this point it still drove fine, shifted gears properly without any grinds/pops, idle was good and accelerated normal. Long story short, I thought the noise was the release bearing and went ahead and changed the clutch, flywheel, release bearing, etc and reattached the transmission. I also went ahead and changed some seals, spark plugs and the distributor(accidentally broke it). After I put everything back on, everything seemed fine besides the fact that I found out it wasn't the release bearing. BUT now the problem is 25% of the time when I drive, my car will decide it doesn't want to accelerate normal anymore. If I am in the city, the rpm will take forever to pass 3-3.5k rpm, and when I am on the highway it will take forever to pass 60mph.
I have tried researching this before but it seems though for everyone else, it happens 100% of the time. This problem only occurs for me SOMETIMES. I want to think it is just the transmission(which I plan to change once I find one since it seems like no one wants to sell their transmission), but this did not happen before. I am sure I attached the flywheel, clutch and pressure plate correctly also.
Please let me know if anyone has any ideas on what can be the culprit.
Old Mar 8, 2017 | 05:43 AM
CandyRedRC46's Avatar
Default Re: In need of some advice!
Seems like these issues are ignition related, maybe the ignitor, whether it is the oem ignition components failing or a new aftermarket ignition component not being up to spec, it seems to happen a lot.
Old Mar 8, 2017 | 06:28 AM
tony_2018's Avatar
Fish Twig
You replace distributor, did you do anything else that is required to be done when replacing the distributor?
Old Mar 8, 2017 | 12:08 PM
As in setting the ignition timing with a timing light, while in diagnostic mode?
Old Mar 8, 2017 | 02:08 PM
jkeokham's Avatar
I was thinking that was a possibility. I heard of some aftermarket distributors just not being up to par. Maybe I can find a my distributor and replace the internals. The teeth on my old distributor broke so that was the reason for buying a new one.
Old Mar 8, 2017 | 02:09 PM
jkeokham's Avatar
Not that I know of. Are you referring to checking the timing with a timing light?
Old Mar 10, 2017 | 12:54 AM
wunfstgsr's Avatar
Loved
Community Favorite
Yea check your timing when replacing the distributor or moving it ect. Even just a tiny tiny bit off it will affect performance greatly when timing is not set to spec.
Old Mar 13, 2017 | 05:21 AM
Check the ignition timing with a light, while the car is in diagnostic mode.
SPITVENOM67
Oct 12, 2012 09:33 AM
KwunEg6
Transmission & Drivetrain
Sep 6, 2009 07:02 AM
SSBlueDC2
Oct 24, 2003 02:25 PM
DeDonDeRosa
Nov 23, 2002 09:03 AM
