Need Help tryin to solve this??
Old Aug 3, 2004 | 05:46 PM
DrewQ1's Avatar
Default Need Help tryin to solve this??
How do you know if an integra comes with keyless entry? Mine is a 95 ls-se
When i bought the car the guy didnt give me any remotes and i work at honda dealership and i came across another Acura remote from an RL but it wouldnt program and i tried 2 other remotes from a 00 civic and an 02 civic but it didnt work but i was able to make them work again for those cars after i was messing with them.
I had called an Acura dealership and they said if it has keyless entry there should be a red light above the steering column. Is that true?
So how do i know if it has keyless entry and what year remotes should i use? Thanks alot guys. I really need the help.
Modified by DrewQ1 at 12:35 AM 8/4/2004
Old Aug 3, 2004 | 07:18 PM
adrenaline-racing's Avatar
Default Re: Need Help tryin to solve this?? (DrewQ1)
On my 1996 Gs-R the brain for the alarm is mounted to the bottom of the drivers seat. I would check there because are the factory wires are already ran there. If it has keyless entry the brain should be there.
Good Luck
Old Aug 3, 2004 | 08:36 PM
DrewQ1's Avatar
Default Re: Need Help tryin to solve this?? (adrenaline-racing)
i'll check.
Old Aug 3, 2004 | 08:41 PM
95integraLS's Avatar
I have a 95 LS SE but i think the original owner had an aftermarket Code Alarm installed.
Old Aug 4, 2004 | 07:00 AM
DrewQ1's Avatar
wed bump
Old Aug 4, 2004 | 04:15 PM
DrewQ1's Avatar
evening bump!
dark_reverie
Mar 3, 2011 10:14 AM
froogle29
Audio / Security / Video
Sep 27, 2009 05:38 PM
taterbug
Jul 16, 2009 06:23 PM
weight
Nov 19, 2006 12:00 AM
DrewQ1
Aug 4, 2004 04:14 PM
