need help throttle cable
i have a 96 integra with a b16 motor. the throttle cable right now doesnt fit right, its zip-tied. what cable do i need to get to make it fit right so i can adjust the idle? thanks.
the cable i have in my car right now im guessing its a b16 cable. im not sure, i was wondering if anyone knew previously which cable is shorter / longer. the cable is short so the nuts that are supposed to go onto the bracket cant because its too short so rather than being screwed its zip-tied. i took off the throttle body and messed with the spring and now i need to get a new cable because my idle is way off. so i needed to know which cable should i get? its a db8 integra.
are you sure an itr cable will fit? i heard something about the throttle being backwards on gsr throttle bodies. the dealer doesnt have either the gsr is out of stock and the itr is special order. anyone have any other ideas? thanks.
yesterday i took out hte throttle cable, the one in the car was longer but the nut spots dont line up with the bracket. the way it is in the car now is from the fire wall it comes around and goes near the brake master cylinder(because its so long), then i zip-tied it to the a/c line and followed it through the bracket, zip tied it to the bracket, and into the throttle body. the problem is, its only secured by zip-ties.
http://ms0834.tripod.com/throttle.jpg
make a bracket to extend or shorter to meet your need. It's cheapest way. I use my dx throttle cable for my b18b swap. I"ll take a pic if i get a hold of a camera.
Mixmasta
Jul 14, 2008 06:30 AM
civic889802
10
Dec 27, 2005 12:15 AM
