need help on these ecu codes
Old Jul 26, 2006 | 03:29 PM
gmrnguyen's Avatar
Default need help on these ecu codes
ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?
Old Jul 26, 2006 | 03:33 PM
DC2 Mang's Avatar
Default Re: need help on these ecu codes (gmrnguyen)
can you get the one and two digits numbers? such as 20 or 3
it will make it quite a but earier to look up
Old Jul 26, 2006 | 03:49 PM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmrnguyen &raquo;</TD></TR><TR><TD CLASS="quote">ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?</TD></TR></TABLE>
p0420=Catalyst Systeam Efficiency Below Threshold...Most likely a bad Cat.
p1259=Vtec System Malfuction...Clean the Vtec solenoid, flter might be drity.
p1457=Evaporative emissions (EVAP) Control system leakage EVAP canister systeam)...
Old Jul 26, 2006 | 03:50 PM
bg-33p's Avatar
Default Re: need help on these ecu codes (jdm_bones)
https://honda-tech.com/zerothread?id=978933
evade this honda
Jul 6, 2005 06:05 PM
1999gs-r
Aug 17, 2004 05:14 PM
MIKES
Jul 16, 2004 11:11 AM
JDM TypeR 307
May 8, 2004 06:44 PM
Patron
15
May 6, 2004 08:20 PM
