need help: stoplight problem on my 90 DA
Old Apr 28, 2009 | 10:15 AM
90reda's Avatar
New User
Default need help: stoplight problem on my 90 DA
My brake lights went out on my 90 DA RS... all bulbs and fuses are good when I checked... I went ahead and replaced the stoplight switch but still no brake lights... does anybody know what else I should check for? Any help would be greatly appreciated...thanks HT
Old Apr 28, 2009 | 10:25 AM
MD426's Avatar
Default Re: need help: stoplight problem on my 90 DA
Try a volt meter at the bulb connector, from the switch and anywhere in between if possible.
Old Apr 28, 2009 | 10:29 AM
90reda's Avatar
New User
unfortunately, I dont have access to a voltmeter right now, but I will do that as soon as I get one. So do you it might be the relay?
Old Apr 28, 2009 | 10:31 AM
stocker2shocker91's Avatar
I requested a short story for a title.
i dont think there is a relay in that circuit, its just a switch at the pedal..
you could also get a test light, its cheaper, faster and sounds like it would make the most sense to use in your situation
also do the running lights in the back light up when the headlights are on?
Old Apr 28, 2009 | 10:40 AM
90reda's Avatar
New User
I will try the test light...thanks
eli1838
Dec 27, 2009 03:09 PM
31flavorscivic
Dec 17, 2008 11:01 AM
99delsol
Sep 14, 2006 08:01 PM
6doorsentra
Apr 9, 2006 07:41 PM
wakaba_db1
Jul 8, 2005 12:44 AM
