Need Help on Revin problem
Old May 20, 2005 | 02:53 PM
B18C5VTEC's Avatar
Default Need Help on Revin problem
ok I have a 94 integra ls and recently everytime I first turn on the car it revs up an down for about 5 mintures before it warms up then it stops and I havent figured out what the problem is and I was wondering if anybody had any ideas.
Thanks
Old May 20, 2005 | 03:06 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Need Help on Revin problem (B18C5VTEC)
How far up and down does it go? If it's not too much (i.e.: doesn't go all the up to redline and then zero back and forth ), then it's most likely the IAC. Pretty common problem.
Old May 21, 2005 | 04:02 AM
B18C5VTEC's Avatar
Default Re: Need Help on Revin problem (shamoo)
When I first start the car it revs up to around 2500 rpm and then back down
to zero and keeps on doing that till the car gets warmed up, any suggestions
what I should do. Do I need to replace it? Thank you for replying to me
Old May 21, 2005 | 06:04 AM
Tweakmeister's Avatar
Inspect IACV
check for air leaks around intake system.
Old May 21, 2005 | 08:05 AM
HoUTX98GSR's Avatar
Default Re: Need Help on Revin problem (Tweakmeister)
yeah.. do a search for iacv fix or something... someone posted something awhile back on how to clean it out... i heard it works most of the time using some chemtool in a baggy or something.
aveink07
Jan 7, 2011 11:45 AM
Red-Rag-B18
May 6, 2010 02:30 PM
fullerkent06
Feb 10, 2007 05:25 PM
moonraker
Dec 26, 2005 09:19 AM
Eluzion
May 8, 2003 08:04 AM
