need help plz
Old Dec 5, 2006 | 06:04 PM
kona_4door's Avatar
Default need help plz
battery still good everything works but car dosent start,it clicks once in a while,but das bout it plz help
Old Dec 5, 2006 | 06:09 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: need help plz (kona_4door)
Check your battery terminals. They could be loose.
Old Dec 5, 2006 | 06:25 PM
kona_4door's Avatar
Default Re: need help plz (Dogginator)
still tight jus checked um,thanks for da info though
Old Dec 5, 2006 | 06:30 PM
Sam92Teg's Avatar
Check the connections at the starter then, including the little clip under the rubber boot. The battery can run all the accesories and still have a weak charge, so make sure it is charged up. If all else is fine, then it starts to look like the starter.
dvlsfan30
Feb 11, 2009 09:45 AM
jamie9500
Jul 3, 2006 03:59 PM
iheartmyej8
Feb 5, 2006 03:10 PM
92CivicSIRhb
10
May 4, 2005 11:44 AM
sleepin91teg
May 29, 2004 11:53 AM
