Need help with installing AC
Old Mar 18, 2008 | 01:30 PM
skata89's Avatar
Default Need help with installing AC
Well Im putting ac back on my car finally but I have no idea where to start. I have everything just dont know where it all goes. So if someone could take some pictures of theres that would be really helpful. I also read that I should replace all the O rings. Where do I get those and where do they go?
Old Mar 19, 2008 | 05:01 AM
skata89's Avatar
bump
Old Mar 19, 2008 | 06:03 AM
crazyguy's Avatar
Default Re: Need help with installing AC (skata89)
all the pipes should only go in one way assembly. u can lay all the pipes on the ground and figure it out. i dont know if you have got everything. for my ac setup , i didnt replace any o rings. but u will need to get a new ac dryer/receiver.
Old Mar 19, 2008 | 06:08 AM
VTEC-DA's Avatar
Start with the bigger items like the compressor etc. From there, you should be able to piece it back together. Just remember, there is only one way it all goes back in so if something doesnt seem to fit right, dont force it, its probably in the wrong spot.
Old Mar 20, 2008 | 10:43 AM
skata89's Avatar
where do the lines connect to the fire wall?
Old Mar 20, 2008 | 11:08 AM
jomama's Avatar
you, my friend, will need a helms or something equivalent. you could try going off a schmatic like sonsacura.com or something similar. like others have said, start with the large items first. for taking out to begin with as for the o-rings, you'll probably want to get new ones since you've probably had it out for a while... get those from a honda/acura dealer or sonsacura.com or majestic honda if the parts are cross-referenced for hondas.
Old Mar 23, 2008 | 02:52 PM
skata89's Avatar
well jomama I didnt remove it bought the car like that 3 years ago. And the ac stuff is coming from my friends integra.
23LX23
Jul 17, 2010 10:30 AM
erikiksaz1
Sep 24, 2004 07:50 PM
variable_x
Aug 31, 2002 11:08 PM
See Are X
Apr 19, 2002 09:49 PM
