Need help from the Guru's
Old Apr 29, 2009 | 06:24 AM
ice-burg-slimm's Avatar
Default Need help from the Guru's
I have a built GSr head Ferrea internals.When i torque the the cam caps and rails down,when using GSR or Skunk2 cams,i am unable to turn the camshafts by hand.Caps and rails are torqued to 18lbs,problem stays the same if torqued to 10lbs.
Can some one tell why this happening?
Old Apr 29, 2009 | 06:32 AM
Schister66's Avatar
Man U FTW
Default Re: Need help from the Guru's
You shouldn't be able to turn the cams by hand...a more appropriate thread would be the case when you could turn them by hand...then you have a problem. The only real way to adjust the cams is by putting a 1/2" drive ratchet on the bolt which holds the gear onto the cam and turning it. Just make sure to have a gentle touch or you'll have to go around another time...you cant go counter-clockwise or the nut will simple loosen. Have fun
Old Apr 29, 2009 | 06:43 AM
That's exactly what the prob is,when i put the ratchet on it i still can't turn the cams,if i try any harder i'm going to snap the bolt.I'm just not sure why they are so tight.
Old Apr 29, 2009 | 09:18 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Apr 29, 2009 | 09:22 AM
jdm_bones's Avatar
You can turn the old ones by hand because they are worn down, and have a clearance there, and don't for the new ones, because they are new they don't have a clearance as large as the old cam...Make sure to use moly grase one them new cams so that they brake in properly...
EF'GSRrr91
12
Sep 18, 2014 06:59 AM
LSTurbo23
Oct 22, 2011 08:13 AM
honda_ek9
Feb 23, 2008 07:28 PM
an2ny888
Jul 26, 2005 01:11 PM
Twigster311
Jul 5, 2003 09:17 AM
