Need help with engine codes..
Old Oct 19, 2008 | 08:00 PM
drock305's Avatar
Default Need help with engine codes..
I have a dc4 integra with an LS engine otherwise known as the special edtion.. big whoop!
anyways.. i got it hooked up to a computer the other day because its been acting up for a while.. the computer gave a few diferent codes..
P0107 = Map Sensor Low Input
P0122 = TPS Sensor Low Input
P1508 = Idle Air Control Valve Circuit Fault
P0505 = IAC Valve System Fault
the car is doing the whole thing where it bobs up and down from about 500rpm to around 3k rpm..
what should I do first to fix the problem?
deewhite06
Nov 12, 2007 09:52 PM
DannyITR
Jul 21, 2004 05:10 PM
civictyper99
May 19, 2004 02:41 AM
civictyper99
May 18, 2004 08:35 PM
phrasathane
Nov 21, 2003 05:25 PM
