Need help diagnosing my Check Engine light issues...........
Old Aug 27, 2002 | 05:03 PM
Rah Rah's Avatar
Default Need help diagnosing my Check Engine light issues...........
My car: 92 Integra LS
My situation: First I had error codes 1, 7, and 43. Tried to reset the ecu, but it didn't work. Replaced the throttle body/tps sensor. Error code 7 was eliminated. Now, I'm down to 1, the oxygen sensor, and 43, fuel system supply. Could it be a simple fuel filter problem. Any thoughts?
[Modified by sando112, 1:17 AM 8/28/2002]
Old Aug 27, 2002 | 05:05 PM
poison's Avatar
Default Re: Need help diagnosing my Check Engine light issues........... (sando112)
when did you last replace the pump or fuel filter?
Could be fuel filter, as well as fuel pump, I would make sure both are working.
I would start with the cheapest and do trial and error in that area
good luck man
[Modified by poison, 7:07 PM 8/27/2002]
jdm mini me
11
Mar 28, 2010 05:22 PM
mugencx
Nov 16, 2008 03:29 AM
goirish
Feb 16, 2006 07:26 PM
GTEC913
Jun 1, 2005 12:13 AM
zeke mccune
Jun 12, 2004 05:42 PM
