need help: climate control lighting
only like a quarter of my climate control lights up and some lighting is really dim. i replaced the climate control with a different one but still the same problem. ground seems to be ok. any ideas on what can be the problem, dash harness?
all help will be appreciated
thanks in advance
thanks in advance
MM&Y of car would help.
Either way, pull the HVAC control head, [climate control] and test the red/black lead(s), [illumination power] should be 12V+ when park/head lights are on, if good test the red lead(s), [illumination ground, from "Dash Lights Brightness Controler" continuity to ground will change as you rotate the DLBC, when turned all the way up there should be full continuity the ground. 94
94preludeguy
10
May 18, 2014 10:03 AM
jae401
May 13, 2013 09:14 PM
