Need help with clear corners
Old Jan 24, 2003 | 01:55 PM
Ben-VTEC's Avatar
Default Need help with clear corners
I recently bought some clear corners for my teg and im having trouble getting the smaller of the two bulbs back in. If anyone can give me some help id really appreciate it, they seemed to have messed up my whole electronic system because one of the bulbs isnt in tact and all the lights on my car flash when i try to use the turn signal. If anyone can tell me how to get that bulb back in there id reall appreciate it.
Old Jan 24, 2003 | 02:35 PM
EL Vap133's Avatar
Default Re: Need help with clear corners (Ben-VTEC)
Is the hole too small or too big?
Old Jan 24, 2003 | 04:46 PM
Ben-VTEC's Avatar
Default Re: Need help with clear corners (Vap133)
seems to be the right size but the bulb wont lock into place.
Old Jan 24, 2003 | 04:49 PM
ahead's Avatar
yea clear corners can be a pain in the ***. you just got to wiggle the pieces around to make it lock up tight. goodluck
Old Jan 24, 2003 | 05:38 PM
GirlyGS-R's Avatar
Default Re: Need help with clear corners (ahead)
Old Jan 25, 2003 | 10:33 AM
Ben-VTEC's Avatar
OK, heres an update....I got all the bulbs in place and latched in, but still when i try to use a turn signal both the front blinker signals flash and all the gauge cluster lights flash too. Anyone have any ideas?
Old Jan 25, 2003 | 12:39 PM
97gSrkId88's Avatar
check to see if you put the bulbs in backwards or you might of crossed a wire. check all ur wiring you did around.
Old Jan 25, 2003 | 12:43 PM
preludexl's Avatar
I got mine installed but the bulbs could be brighter. I saw following my gf when she was driving it in the rain...and it was kinda dim compared to the stock yellows.
Old Jan 25, 2003 | 03:05 PM
Ben-VTEC's Avatar
Default Re: Need help with clear corners (preludexl)
Allright one of the bulbs was bad so i went out and got all new Sylvania amber corner bulbs. The blinkers nwo funtion properly except my right one blinks too fast. It looks like the harness might not be connecting all the way but im not sure. Any ideas?
Old Jan 25, 2003 | 08:20 PM
SupaTegRS's Avatar
if the right one is blinking too fast, check to make sure the bulbs are fully seated on the right side.....that usually means one of the bulbs is not working
Old Jan 29, 2003 | 04:58 PM
ahead's Avatar
Default Re: Need help with clear corners (SupaTegRS)
from what ive read if the ground wire isnt connected the blinker will blink much faster.goodluck
Wsteun
Nov 5, 2006 09:58 PM
mwieczorek43
Feb 3, 2006 02:05 PM
Hatch It
Jan 19, 2005 10:07 AM
1Tym
Jul 16, 2002 04:53 PM
98SILVERGSR
Feb 5, 2002 07:59 PM
