Need help ASAP please!
Old Jul 23, 2006 | 09:12 AM
suken19's Avatar
Default Need help ASAP please!
Hi guys! I have searched but found no answers. My question is, how do remove the rotor cap or that black round plastic piece that behind the distributor cap?
Thanks
Old Jul 23, 2006 | 09:26 AM
b20integrapower's Avatar
Default Re: Need help ASAP please! (suken19)
do you mean the how do you remove the rotor? there is a screw behind it. unscrew it and it will come off. i wish i had a picture. you may have to turn the crank to reveal the screw though. someone else chime in with pics if you can.
Old Jul 23, 2006 | 09:35 AM
suken19's Avatar
Default Re: Need help ASAP please! (b20integrapower)
I don't see that scree anywhere. How is their a screw behind the rotor because their this big black plastic square thing that is blocking it which I think it would impossible to access that screw. Can someone help me please!
Thanks
Old Jul 23, 2006 | 09:41 AM
suken19's Avatar
Also, what do mean I might have to turn the crank? Is that putting my key in the ingition and turn it but not starting the car? Just noting that my distributor cap, the black plastic with sparkplugs wire connecting to it is taking off right now.
Thanks
Old Jul 23, 2006 | 09:43 AM
BlueIntegraBoy's Avatar
Yes, with the distributer off, crank the car. After each turn, check behind the rotor to reveal a screw. If you don't see it after the first crank, crank it again. Oh, just remove the big black piece. It comes off.
Old Jul 23, 2006 | 09:52 AM
suken19's Avatar
Default Re: Need help ASAP please! (BlueIntegraBoy)
I did tried to remove that plastic piece, but that bitch wouldn't come off. Anyways, thanks for helping guys. I will go and tried to remove the rotor now and will come back if I still need help.
Thanks again.
Old Jul 23, 2006 | 09:57 AM
suken19's Avatar
I dont' see the screw anywhere. Am I suppose to start up the car? I hope not because I was told not to start the car while the distributor cap is off. Anyways, about the black removable piece thing, from what can I tell, it will not comes off unless the rotor is off. Can someone confirm this for me. I tried turning my key form one to three, and I don't see the screw anywhere. Is the rotor suppos to rotates and I crank the car?
Thanks
Old Jul 23, 2006 | 10:10 AM
suken19's Avatar
BTW, I drive a 99 integra GS.
Thanks
Old Jul 23, 2006 | 10:24 AM
suken19's Avatar
Done! Thanks for all the help!
Old Jul 23, 2006 | 10:27 AM
53JDMDC2's Avatar
there is a screw. You just have to look harder. Its on the rotor shaft. Push the plastic piece back, it wont come off untill the rotor is off.
beanwagon
Aug 3, 2009 02:57 PM
xsilvercivicx
Aug 22, 2004 01:35 PM
vuthe32
Sep 7, 2003 02:22 PM
93SSPHatch
May 30, 2002 02:55 PM
gsr squirrel
Apr 25, 2002 07:08 PM
