NEED HELP ASAP!!!!
Old Jul 9, 2004 | 08:55 PM
ch0o on this's Avatar
Default NEED HELP ASAP!!!!
put a b18b in a 90 integ and havin problems startin it up.
starter wasn't operating so we unbolted it and directly wired it up to test it
and it operates just fine however when we bolt it back in, it again doesn't work.
any suggestions?
need help ASAP thanks.
Old Jul 9, 2004 | 10:07 PM
patmcd's Avatar
Default Re: NEED HELP ASAP!!!! (ch0o on this)
Did you make sure the power feeds in the car are live? Fuses?
Old Jul 9, 2004 | 11:41 PM
JDM-TypeRteg's Avatar
make sure the wires are live and have power running through them, or it could just be a miss connection for the power
Old Jul 9, 2004 | 11:53 PM
ThatRicerDaniel's Avatar
Default Re: NEED HELP ASAP!!!! (JDM-GSRteg)
all the power is correct and exactly where it should be .. 12.5 volts all the way around .. i tested it at every point including at the starter.. the starter is also verified that it has a ground.
blackdude
Nov 30, 2006 07:23 PM
Bulldogg83
Aug 10, 2006 12:59 PM
91SIR
Feb 20, 2003 10:41 AM
