need help ASAP!
Okay, i am swapping out my LS and putting in a b20z w/ jdm gsr tranny, but then i have a problem, my new clutch setup is ACT 6 puck with Clutch Net Stage three pressure plate with 8lb CM flywheel, all brand new, when i installed the clutch and was putting in the tranny it wouldnt go all the way in, it'll have like a half an inch gap in between the motor and the tranny and i cant screw in the tranny in. What could be the problem??? My old LS stock flywheel seems like its different from the b20 flywheel, the stock pressure plate that came out of my friend old b20 wouldnt fit the CM flywheel, the bolt pattern seems kinda off, but the stock LS flywheel fit the CM flywheel fine, we try swapping all the parts back and fourth to see what fit and doesnt fit, so we end up putting in the b20 stock pressure plate and flywheel with my 6 puck and everything fit, i having a guess that it could be the new pressure plate or the CM flywheel that could be the wrong setup for my motor, anybody have any ideas what else could it be??? btw the Clutch PP and CM FW fit perfectly fine together, isn't all b-series suppose to be interchangeable??
remaxxxk
Mar 1, 2006 09:11 PM
luderone
Sep 13, 2003 02:01 PM
