need help ASAP!!
Problem: Tranny or clutch im not sure
Car: 1996 Integra GSR
ok i parked my car for about 45 mins and when i go back out to start it, it starts perfectly.. i try to shift into 1st so i can gtfo and it feels like theres a brick wall blocking EVERY gear so im stuck in neutral.. when the car was off i put it in 1st and then tried to start it, it stalled out like the clutch wasnt even engaged.. so now my car is parked outside of my job until i can figure out what the problem is
this happened before right after i got off the turnpike, it wouldnt go into any gear and after like 10 mins of waiting it worked flawlessly
any suggestions? im guessing its my master cylinder maybe? no idea
Note: no visible leaks on the inside of my car
I'd say defffff check your resivoir for the clutch the little one..same thing happened to my friend last year, put some fluid in it pump a few times, and add more if needed!
that honda kid
Mar 10, 2010 02:20 PM
integnewb
Mar 17, 2006 12:18 PM
hybrider
May 6, 2002 04:54 PM
