NEED HELP ASAP!!!!!!!!!
Old Oct 3, 2007 | 04:53 PM
1a's Avatar
1a
Default NEED HELP ASAP!!!!!!!!!
i need help with a few things that are ticking me off.
1. My transmission I pray is not going out, someone told me i can drain it and refill it. When i engage reverse it will grind sometimes. When I shift into second gear and sometimes third.... it sometimes grinds.... any idea? please no bad news lol I dont think it would be my clutch because it still feels good and not worn down.
2. my short shifter is loose, i went over a speed hump, and my car is lowered and i felt it scrape the shifter,.... can i tighten it? or any ideas?
3. my car makes wierd reving noises when im in neutral any idea?
4. my car is hesitant when starting it up sometime, someone told me a fuel pump but im not sure..
ANY HELP WILL BE GREATLY APPRECIATEDD!!!!
Old Oct 3, 2007 | 04:55 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: NEED HELP ASAP!!!!!!!!! (mck52689)
1) Change the fluid...
2) Check bushings I would say...
3) Your IACV could use cleaning (IACV= Idle Air Control Valve)
4) Try changing spark plugs, atleast that helped me out...
Old Oct 3, 2007 | 05:00 PM
1a's Avatar
1a
Default Re: NEED HELP ASAP!!!!!!!!! (Project95LS-VTECNoMore)
Thanks alot dude, im gonna try it out tomorrow.... i hope thats it, i bought a 91 integra ls for 1k with 200+k miles and 100 on the motor.... but it still needs struts axle and some work but other wise im happy... i just hope it is the tranny fluid
Old Oct 3, 2007 | 05:10 PM
Byaaah!'s Avatar
No problem, I just read a thread where some guy said his 3rd, 4th and reverse grind but it is all good, so you might luck out but just don't abuse your tranny ...
Old Oct 3, 2007 | 06:46 PM
jdm_bones's Avatar
Drain your tranny fluid and refill with GM sincro mesh
Check all bushing on the shift linkage and replace if needed!
If that doesn't do the trick, start saving up some money for another tranny.
jdm_obsession88
Transmission & Drivetrain
Jul 24, 2010 12:51 PM
Rolo30
12
Apr 25, 2009 03:19 PM
soto2635
Mar 15, 2009 06:42 AM
luvmihatch
Feb 22, 2008 09:01 PM
sk8
Apr 19, 2004 10:06 PM
