need help
i have a 95 se and just did a tranny and clutch.but when i push the clutch pedal to start the car it just went to the floor.i tried bleeding it but it dosnt build pressure or anything.if u have any ideas.please let me know
Process of pumping a clutch usually takes two: Open your resevoir for the clutch lines fill it up if its empty, have someone pump the clutch pedal numerous times then tell them to hold it all the way down. While they are holding it down you loosen the bleeder on the slave cylinder which the brake fluid will come out. Then tigthen it back down. Once you tighten it back down tell the other person to start pumping again. Repeat this as many times as it takes. Sometimes it will take awhile but just be patient.
hondaless
Apr 2, 2009 08:58 AM
