????????Need Help????????
I bought a 2000 integra front seat to replace my 1995 front seat. I searched before purchasing the seat and a lot of H-T member said that its a bolt on but unfortunately its not. I need to swap the rails/slider, here's my question how can I remove the 2 adjustment ***** on the driver side? Please look at the boxed area, this is the reason why its not bolt on. thanks for any suggestions.
http://www.ofoto.com/PhotoView...71406
Modified by civic91 at 8:22 AM 9/28/2004
Modified by civic91 at 12:13 PM 9/30/2004
I recommend this site for the exploded diagrams.
http://www.acuraparts247.com
Do those ***** need to be removed to install the seat? Would it be possible just to swap the cushions and upholstery?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">I recommend this site for the exploded diagrams.
Do those ***** need to be removed to install the seat? Would it be possible just to swap the cushions and upholstery?</TD></TR></TABLE>
I'm not sure which one is easir to swap the cushions and upholstery or the rails and slider. I started to dismantle the new seat but I don't have enough tools to remove all the bolts and two of the bolts are pretty tight that I got scared I might brake it. Thanks for your suggestion.
i think you're mistaken. all 94-01 integra front seats mount in the exact same way/same places. you should try again and slide the rails around to get them to line up with the bolt holes.
That's not my problem if you look at the picture, the rail (front) is not bend, may be the old owner of this seat swap the rail or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano-Red GSR »</TD></TR><TR><TD CLASS="quote">helm book shows nothing about bolts..so i guess just pull them off..there is clip too..like U shape clip..sorry i dont have scaner..</TD></TR></TABLE>
can you take picture of the page that show the U shape clip? What's the instruction in the helm book just pull them off? thanks in advance...
i have a 94 teg and i put in 2000 integra GS R seats in with no problem just bolt right in....i think the guy who sold you the seats change the rails or something..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanna b R »</TD></TR><TR><TD CLASS="quote">i have a 94 teg and i put in 2000 integra GS R seats in with no problem just bolt right in....i think the guy who sold you the seats change the rails or something..</TD></TR></TABLE>
that's what i'm thinking that's why i want to swap rails, but i want somebody to tell me how to remove the adjustment **** so I can get to bolt that hold the rails/slider. can i just pull out the ****? all i'm asking is how to take the **** out? thanks again.
Looks as though the tabs on the rails have been bent up (circled in the pic)... Try bending the tabs approximately 15 degrees down...I'll bet they line-up to the mounting holes. If NOT just swap rails....
GOOD LUCK!!!
Modified by bluecivic107 at 3:05 PM 9/29/2004
GOOD LUCK!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">There should be a retaining clip inside of the ****. Remove that and the **** should pull off. The clip is item 23 in this picture:
Thank you very much. That's the info I was looking for.
</TD></TR></TABLE>Thank you very much. That's the info I was looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecivic107 »</TD></TR><TR><TD CLASS="quote">Looks as though the tabs on the rails have been bent up (circled in the pic)... Try bending the tabs approximately 15 degrees down...I'll bet they line-up to the mounting holes. If NOT just swap rails....
GOOD LUCK!!!
Modified by bluecivic107 at 3:05 PM 9/29/2004</TD></TR></TABLE>
I did swap the rails yesterday afternoon after work and the seat is in my car now but after bolting the seat back to the car I found this two washer (1 plastic and one real thin metal) here's the link to the photo, sorry until now I can't figure out how to insert picture.
http://www.ofoto.com/PhotoView...42406
GOOD LUCK!!!
[/QUOTE]
[/QUOTE]
can someone identify this two washer for please.......................
[/QUOTE]
1whitedc2
Jan 24, 2005 03:35 PM
Civic44
19
Apr 21, 2003 09:06 AM
