Is this my problem. Pics inside
Old Mar 20, 2004 | 03:43 PM
Boost2NA's Avatar
Default Is this my problem. Pics inside
Yesterday we installed a head on my car. It went good until we started it. I had white steam coming from the head. The 2 cylinder had coolant all over it so we did a compression test. Results are 210-165-210-210. We knew we had to pull the head and check some stuff out. When we pulled it we saw this little gouge in the head. My friend thinks its the water way but not that I looked at it more I think it is the oil passage in the head. He was thinking it was leaking into that combustion chamber and causing it to smoke. Here are some pics of the gouge. The car is a 01 GSR and it is a P72 head worked with skunk 2 valvetrain
IS that a waterway and if it is can that cause what I was describing. It goes clean through from the hole to the combustion chamber (the gouge). If that is a return line Im guessing that my head is warped or something. Everyone post up what u think. Thanks.
Old Mar 20, 2004 | 05:09 PM
Code Blue's Avatar
Default Re: Is this my problem. Pics inside (Boost2NA)
it could be that gouge or the number two cylinder not sealing the right way. did you reuse the headgasket?
Old Mar 20, 2004 | 05:15 PM
Boost2NA's Avatar
Default Re: Is this my problem. Pics inside (Code Blue)
no it was a brand new Mugen gasket.
Old Mar 20, 2004 | 06:12 PM
Ron Carroll's Avatar
That is a water passage way next to the gouge, you will need to have the cylinder head surfaced to get rid of the gouge, so it will seal.
Old Mar 20, 2004 | 06:13 PM
onePOINTsix's Avatar
thats a coolant passage, the oil goes thru the oil jet on the back side and back into the block on those big oval things on the back and the oval looking thinks on the front on the far sides... that really dosnet make sence but oh well
Old Mar 20, 2004 | 08:18 PM
Boost2NA's Avatar
Default Re: Is this my problem. Pics inside (itaintegra52)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itaintegra52 &raquo;</TD></TR><TR><TD CLASS="quote">That is a water passage way next to the gouge, you will need to have the cylinder head surfaced to get rid of the gouge, so it will seal.</TD></TR></TABLE>
this is what i was hoping to hear. Here is my situation. I was using a Mugen headgasket before. Since I have to resurface the head what is the max I can mill off the head to still be able to use anonther Mugen headgasket (im not a big fan of milling id rahter have the gasket there. Or should I just mill the head lets say .020 and use a OEM gasket. Here is what I had planned if the gouge is less than .010 I will get it resurfaced and order a new mugen gasket. If its .010 or more I will just tell them to mill it .020 and I will use a OEM gasket. Please help on this I need to do it fast. Oh yeah the cams being used are S2S2
Modified by Boost2NA at 11:49 PM 3/20/2004
Old Mar 20, 2004 | 10:14 PM
mr.beeks's Avatar
I had a similar problem in where
cylinder 1 and 2 where conected.
took it to local machine shop and the machinist
filled the gap, and it worked..
so you dont have to shave nothing...
Old Mar 20, 2004 | 11:28 PM
Fkned's Avatar
your pics are really blurry,but the gouge is definately the problem,get the head surfaced to get rid of it.It's your call on the head gasket depending on the amount taken off.Always get the head resurfaced before installing it's not worth the effort of re-doing the whole process for this very problem.
Old Mar 21, 2004 | 06:51 AM
Boost2NA's Avatar
Default Re: (fkned)
so what is the max amount I can take off and still be safe with the skunk 2 stage 2 cams with a mugen gasket. Thanks.
Old Mar 21, 2004 | 08:05 AM
Attoir's Avatar
Default Re: (Boost2NA)
1/2" inch, you'll be aight. :-P
bump.
Old Mar 21, 2004 | 10:13 AM
Have the head milled to factor min. specs and run the mugen gasket, the machine shop will know what the spec for your head is. We run our race cars at .0025 under min specs so you should be fine with just going to min specs.
Old Mar 21, 2004 | 11:20 AM
Boost2NA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost2NA &raquo;</TD></TR><TR><TD CLASS="quote">so what is the max amount I can take off and still be safe with the skunk 2 stage 2 cams with a mugen gasket. Thanks.</TD></TR></TABLE>
anyone..................
Old Mar 21, 2004 | 04:33 PM
Boost2NA's Avatar
well i did some math and I came up with running a Mugen headgasket is equal to milling 0.026244094491 off your head. Knowing this, since I have a gouge in it that is prolly more than .004 inch deep im going to just mill the head .020 and run a stock gasket. People say that .030 is the max to go on these heads and I dont want to come close to that or even dare go over it.
Old Mar 21, 2004 | 05:13 PM
MAX_CFM's Avatar
send it too me i will weld it and mill just a few thou
Old Mar 21, 2004 | 05:24 PM
cjohnson_2's Avatar
Default Re: (MAX_CFM)
have someone carefully weld it. (pray they dont warp the head) then let them just take a few thousandths out of it.
turbo1spunn
Engine Management and Tuning
Mar 31, 2016 10:53 PM
Slammd Sol
May 26, 2007 08:31 PM
hb_guy
10
Oct 31, 2005 03:44 AM
hb_guy
Oct 30, 2005 01:41 PM
tuan...
Sep 18, 2004 09:50 PM
