MY FIRST DA9....Help.
Old Oct 25, 2009 | 10:45 PM
DOUBTS.72's Avatar
Post MY FIRST DA9....Help.
1991 Acura Integra DA9 B18a1. Got it Under 800 Guy didnt know much about the car interior is 8 out of 10. Has an idle Problem . ECU is giving me a Code 43 and a code 7 . Correct me if im wrong, but 43.is Injectors ?7. is TPS. sensor.? headgaskets(guy said Compression was at 180p in all 4) where done. New spark plug cables, and dizzy is Working well. Smells like a lot of burned fuel when i turn it on. Im Getting the new injectors and tps sensor on Wend(will update on it). Just want to know if you guys had the same problem, and if there might be other things to look for other than code 43, and 7.
Thanx .
Here are some pictures of it...i think i got a great !!deal on it what you guys think?
http://i205.photobucket.com/albums/b.../IMAGE_178.jpg
http://i205.photobucket.com/albums/b.../IMAGE_182.jpg
http://i205.photobucket.com/albums/b.../IMAGE_183.jpg
http://i205.photobucket.com/albums/b.../IMAGE_184.jpg
http://i205.photobucket.com/albums/b.../IMAGE_177.jpg
Old Oct 26, 2009 | 03:32 AM
consumer's Avatar
Default Re: MY FIRST DA9....Help.
might want to try a more active forum, wich i also am having a hard time finding..
Old Oct 26, 2009 | 05:27 PM
DOUBTS.72's Avatar
thanx ..ill take your advise ....since your the only one that answered.
Old Oct 26, 2009 | 05:54 PM
dalejrfan88's Avatar
http://g2ic.com/forums/
Old Oct 26, 2009 | 06:21 PM
DOUBTS.72's Avatar
Originally Posted by dalejrfan88
thanx. ill see was up .
Old Oct 26, 2009 | 06:52 PM
Gizz-R's Avatar
idle problem. Check your idle air control valve. Clean it out with some carb cleaner. For more info on it just search up IACV or your Fast idle thermal valve FITV.
Old Oct 26, 2009 | 09:23 PM
DOUBTS.72's Avatar
cool. Thanx...i will let you know, if this works for me tomorrow thanx. man.
Old Oct 27, 2009 | 06:21 PM
DOUBTS.72's Avatar
**Up Date **Oct.27.'09."IACV" i did the clean up. Idle is still bad, thought i too a look at the Spark plugs, and found out they have oil on the top. Did some research and read that is my "valve gasket," that has to be replaced . Just to add to this my oil light keeps on blinking?(any other ideas, other than Tune up?) car does need a tune up and will be taken care of soon (car is sitting). So i made a trip to AZ, and bought some new "BOSCH," spark plugs. Put them in and idle still bad. Tomorrow i will be getting a New Valve Gasket,Injectors,TPS, and will Up date if it helps my idle . till then...
C_Rock77
Feb 4, 2008 02:14 PM
royalfelix
Dec 8, 2007 01:13 PM
PyeeK
Mar 19, 2006 05:27 AM
Waachback
Dec 2, 2003 06:56 PM
Jockobo
Jul 26, 2003 01:56 PM
