My car eats alternators...
Old Jan 27, 2004 | 04:08 PM
91teg4dr's Avatar
Default My car eats alternators...
I have had my 91 Integra RS for about a year. During this time it has gone throuh 4 alternators. I am about to instal the fifth. The last one only lasted a couple of days, the rest lasted weeks to months. What could be causing this, it is getting very expensive. Long story short: WHY DO I KEEP BLOWING OUT ALTERNATORS???
Old Jan 27, 2004 | 04:13 PM
Jer'rome's Avatar
Default Re: My car eats alternators... (91teg4dr)
do you have a system? i remember back in tha day i had 800wt pyramid amp in my prelude.. I went through 4 altenators
Old Jan 27, 2004 | 04:21 PM
oMek's Avatar
Default Re: My car eats alternators... (Crunk'd)
i have the same car i dont go though those i go though a lot of igitons coils maybe ur system but i have a system with a 1600w/ amp so dont know maybe get a new batt.
Old Jan 27, 2004 | 04:38 PM
Jer'rome's Avatar
Default Re: My car eats alternators... (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same car i dont go though those i go though a lot of igitons coils maybe ur system but i have a system with a 1600w/ amp so dont know maybe get a new batt.</TD></TR></TABLE>
yeah whatsup with them coils.. I too have a 90 teg and i blew one last month. so i took off my MSD
Old Jan 27, 2004 | 06:01 PM
oMek's Avatar
no idea but ive put 2 in 6 months. dam coils
Old Jan 27, 2004 | 06:20 PM
mr.beeks's Avatar
are you getting rebuilt alternators?
some of them are dissposable.
and as for the coils specially msd are you guys really
insulation the wires that come out of the distributor?
Old Jan 27, 2004 | 07:33 PM
deepgreengsr's Avatar
Default Re: My car eats alternators... (mr.beeks)
what brand alts are you useing? bosch is gay, Only get denso.
Old Jan 27, 2004 | 07:39 PM
91teg4dr's Avatar
I do not have a system. I do not have a deck or speakers, much less an amp. I have not had any problems w/ ignition coils. I bought new batteries with three of the four alternators, because you can only charge those dam things so many times. The first alternator was brand new, the next three have been used. I know some used parts go bad...but three times? They have been different brands, one of them was a denso. Also I tested each after installing and they all operated normally for a length of time (some shorter than others). I am thinking about getting rid of the car...
Old Jan 27, 2004 | 07:44 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: (91teg4dr)
Hey deep! How is bosch so gay? I would love to hear your story- on the facts you base that on?
Old Jan 27, 2004 | 08:18 PM
Erik_Pb_Foot's Avatar
New User
Default Re: (primo8998)
i go through about 3 a year from overspinning them on my civic (car turns 11k roms... original motor turned 5k) but the solution is SIMPLE...
GET IN THE ZONE &gt;&gt;&gt; AutoZone
Lifetime warranty...
every time i burn one out... i go get another... for free...
i even use their tools and swap them in the parking lot so they don't make interest off my core charge.
Old Jan 27, 2004 | 09:42 PM
91teg4dr's Avatar
Default Re: (Erik_Pb_Foot)
That would be ok if it weren't such a pain in the *** to swap out, i have to pull the brake master cylinder each time...
Old Jan 28, 2004 | 04:47 AM
New User
ouch
well, even though i'd hate to suggest it, you need to buy a new one... you've fried all these used ones but you don't know if they had 400,000 miles on them when you bought them or had been abused by the previous owner, etc....
Old Jan 28, 2004 | 01:07 PM
maxxdout's Avatar
Default Re: (B.CRUZ)
ok, you have a number of problems probably. First off, an alternator is an alternator. Well not really but you get the picture. NO brand is particularly better then the other. If you KNOW for a fact that you electrical system is good, consider doing an alternator output test. Simly done, its a measure of the alternator output voltage while the car is runng. ALso, could you possibly be over tightening the tension on the belt? Doing this will put undo stress on the bearings and fail the unit. This could be another problem.
Please, alittle more info.
Old Jan 29, 2004 | 06:25 AM
Creep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91teg4dr &raquo;</TD></TR><TR><TD CLASS="quote">That would be ok if it weren't such a pain in the *** to swap out, i have to pull the brake master cylinder each time...</TD></TR></TABLE>
Do you find that way faster then doing it the way descibed in the helms?
I hear doing it the way you decribed is much easier.
Old Jan 29, 2004 | 06:38 AM
b16hybridsol's Avatar
don't put the belt on to tight, on the logest run of the belt there should be about a 1/4 inch deflection in it, but no more than a half inch
Old Jan 29, 2004 | 07:30 AM
New User
Default Re: (Creep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creep &raquo;</TD></TR><TR><TD CLASS="quote">
I hear doing it the way you decribed is much easier.</TD></TR></TABLE>
from his title it seems he has a swapped car... the helms doesn't apply to swaps unfortunatly.
Old Jan 29, 2004 | 09:33 AM
91teg4dr's Avatar
Default Re: (Creep)
Still a PITA, but much easier. Two brake lines, and two mounting bolts is all, then bleeding.. Use a 10 mm for lines and a 14 for mounting bolts. The brake lines can be tricky to get back on...
Old Jan 29, 2004 | 09:40 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91teg4dr &raquo;</TD></TR><TR><TD CLASS="quote">Two brake lines, and two mounting bolts is all, then bleeding..</TD></TR></TABLE>
you dont need to disconnect the brake lines , you just need to seperate the MC from the booster.
you guys make things way too complicated...
Old Jan 29, 2004 | 06:34 PM
Creep's Avatar
Default Re: (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
Nice...
Old Jan 29, 2004 | 11:10 PM
ravens31's Avatar
Default Re: (Creep)
my integra eats alternators too
Old Jan 30, 2004 | 02:31 AM
IntEGNYC's Avatar
Default Re: (ravens31)
check the terminal connections. seems to be drawing power somewhere in the system.
Old Jan 31, 2004 | 12:15 AM
91teg4dr's Avatar
I tried at first, but the alternator wouldn't come out for me w/out completely removing the MC?
Old Feb 4, 2004 | 05:00 PM
ok why do bosch components suck compared to denso. Bosch alts go out at around 80k densos go out at around 200k. bosch plugs never last as long as densos. look at the quality of connections and wires on a bosch and look at a denso. Desno has a higher strand count and better connections. Denso just makes a better longer lasting product. Now compare a bosch to a acdelco or some **** from autozone and bosch rocks. but against denso everything bosch just plain sucks. THATS Y!
Old Feb 4, 2004 | 05:41 PM
kablamo's Avatar
Default Re: (IntEGNYC)
ever tested the bad alternators? what goes? bearings/pulley? do they slowly crap out or just go bad out of nowhere? bench-testing a bad one might tell you interesting info (amps it puts out, volts it puts out, either with or without a load)
try seeing if there is a drain on the electrical system.
have you checked the voltage regulator? does the ecu ever have any trouble codes?
if the car isn't in great shape, might be easier just to ditch it... although i'd have a look at the voltage regulator first, and make sure the belt is tightened to spec and staying there (if it gets tighter/looser eventually that could be a big problem).
Old Feb 7, 2004 | 03:29 AM
91teg4dr's Avatar
Well, I pussied out on the repairs, and traded my Integ for a CRX. Electrical prbs aren't exactly my thing. Thanks to everyone fo your help as always.
slowpokecivic
Dec 6, 2006 05:27 PM
slowpokecivic
Oct 17, 2006 08:51 PM
Hehehe I just
Audio / Security / Video
Nov 14, 2004 11:00 AM
sytema
12
Sep 26, 2003 12:08 PM
sportyolds
Mar 12, 2003 12:55 AM
