MSD Ignition Distributor?
Old Nov 21, 2005 | 06:50 PM
ricer4life's Avatar
Default MSD Ignition Distributor?
i Have a 94 gsr and I need some help my distributor has went out and i was curious to know if purchasing a MSD Ignition Distributor would be a wise investment and what are tha benifits from this investment and if this bolts directly up or will i need something else to make it work or relocate something. Here are the specs. for the Distributor- (Pro-Billet Distributor - GS/GSR/LS/RS B18B1/C1 DOHC/VTEC 1.8L 4CYL JDM/USDM - Dual ball bearing guides for accurate and stable high rpm operation - Powerful, multiple sparking ext. ignition module - Uses an external coil for increased voltage output - Hall effect pickup assemblies retain stock ECU functions and improve accuracy - Rynite cap features wid spaced spark plug style terminals and a wire retainer - Cam sync output will signal aftermarket EFI sytems - CNC-machined billet ALUMINUM). SO if you could help me out i would be very thankful.
kkilo
May 5, 2008 01:09 PM
b16hatche
Dec 14, 2005 07:31 PM
dyg2001
Feb 24, 2004 09:38 AM
duckming
Jun 5, 2003 05:17 PM
Leo95SE
Aug 20, 2001 03:59 PM
