Motor Mounts
Old Oct 29, 2001 | 07:06 AM
GSRacer's Avatar
New User
Default Motor Mounts
my friend got his motor mounts broken in an accident. Is there any companies that make aftermarket mounts for his 2000 SI?? should he put aftermarket motor mounts or just plain stock ones?? Where can we get the mounts for a good price??
[Modified by GSRacer, 11:36 AM 10/29/2001]
Old Oct 29, 2001 | 10:36 AM
GSRacer's Avatar
New User
Default Re: Motor Mounts (GSRacer)
Old Oct 29, 2001 | 10:42 AM
FAST94GSR's Avatar
New User
Try energy suspension. summit racing has them. look in any turbo mag for them everybody carries them
Old Oct 29, 2001 | 11:14 AM
Max GSR's Avatar
Just get new stock ones. They really are the best. If you want eXtra stiffness, you can always add the Energy Suspension inserts later, but unless you're racing, you shouldn't need them.
Old Oct 29, 2001 | 12:01 PM
RacingE_Teg's Avatar
Default Re: Motor Mounts (Max GSR)
Old Oct 29, 2001 | 01:38 PM
redlinegsr's Avatar
Default Re: Motor Mounts (RacingE_Teg)
I TOTALLY AGRE WITH RacindE_teg! if you do go with aftermarket motor mounts be prepared for alot of vibrations. the mounts are sooo stiff you can literally feel every shake from the engine!!!!
Old Oct 29, 2001 | 02:30 PM
BoostinDC2's Avatar
Default Re: Motor Mounts (redlinegsr)
just get the stock mounts and upgrade to the hasport rear mount
Old Oct 29, 2001 | 03:26 PM
IN VTEC's Avatar
I've seen a set of complete aluminum alloy motor mounts for the '92-'95 and '96-'01 Civic's. They come anodized red. The only thing is that they cost $350 for a set...and they only replace 3 mounts. I think there are 5 mounts total. Dunno which mount you'd need...probably a lower mount tho.
Otherwise, talk to Mike K on the board down at Naples for stock parts. His prices are low.
[Modified by IN VTEC, 6:28 PM 10/29/2001]
Old Oct 29, 2001 | 03:33 PM
ILOVEGIRLS's Avatar
just get the stock mount. like everyone else says..you can get the energy sus inserts later.
Old Oct 30, 2001 | 09:15 AM
GSRacer's Avatar
New User
Default Re: Motor Mounts (ILOVEGIRLS)
thanks for the replies. where can i get the stock one for cheap??
alx_90ef
20
May 30, 2014 06:31 AM
SweetSIReX
Dec 19, 2008 05:05 PM
hondaapi
Oct 20, 2008 01:52 AM
RidinStock
Feb 4, 2006 09:13 AM
h-spec_crx
Apr 30, 2003 01:03 PM
