motor mount inserts
Old Oct 11, 2002 | 10:42 PM
badnan's Avatar
Default motor mount inserts
does any one have these? like the energy suspension ones? im looking at getting them, but im not sure how hard the install is. and is there realy a noticable difference? the reason i ask is i was readin up on the teamintegra's suspension articles and there was one about reducing wheel hop.
thanks
Old Oct 11, 2002 | 10:55 PM
Paste's Avatar
Loved
Default Re: motor mount inserts (badnan)
Im going to get them soon, my rear motor mount is shot, so mine as well replace all 3... It is kind of hard i think, i cant find the link of the install
Old Oct 12, 2002 | 12:18 AM
vteg's Avatar
New User
Default Re: motor mount inserts (paste)
http://www.hazone.com/default.htm?howto/mtrmount.htm
Mine are still in the garage collecting dust. Over the last 8 months that I have had them I have considered installing them several times, but get too lazy or find something that I would rather do.
Old Oct 12, 2002 | 06:26 AM
JDubya's Avatar
does anyone know where to buy both sets, ES and Prothane, at a dectent price?
Old Oct 12, 2002 | 06:54 AM
ragejed's Avatar
Default Re: motor mount inserts (Hybrid Teg98)
suspension.com for the es...as for the prothane, im still looking.
Old Oct 12, 2002 | 09:46 AM
3rdGteg's Avatar
Default Re: motor mount inserts (ragejed)
I'm aware that these inserts are made to slip over our stock mounts, but what if your stock ones are cracked, etc. Will they still do the job or do we have to get new oem mounts and then throw these inserts over the new ones?
Old Oct 12, 2002 | 09:54 AM
gsrstyle's Avatar
they reduce wheel hop by alot. i went from 11.5 to 10.2 in the 1/8 (ya i sux at driving) just with motor mounts. and thats only with the front 2. im just gonna wait until i take the whole manifold off before i put in the rear one. and install is pretty easy, but its hard to break those bolts loose. we had to use a BIG breaker bar just to get them off.
Old Oct 12, 2002 | 10:14 AM
3rdGteg's Avatar
Default Re: motor mount inserts (3rdGteg)
Old Oct 12, 2002 | 03:51 PM
ragejed's Avatar
ehh, for the price of new ones, depends which one...you can get a full "race" one at hasport.com
Old Oct 12, 2002 | 08:09 PM
JDM_JON's Avatar
I would get Prothane....enexpensive....you can get them from AutolinkMotorworks in Temple City, CA
Old Oct 12, 2002 | 09:53 PM
AW's Avatar
AW
Default Re: motor mount inserts (BucketDC2)
If you are considering replacement of the motor mounts keep in mind that both ES and Prothane engine mounts will transfer more vibrations into the car. If you drive the car on the street I would recommend ES, softer and less vibration. I have owned both and am currently using the ES as the Prothane ones were too stiff. Felt like the windshield would crack when the car was just idling. Also if you do not need the rear mount do not put it in. It transmits the most vibration. The Prothane mount is a bitch to put in as you have to cut out the liquid filled drivers side mount to put it in.
AW
Old Oct 13, 2002 | 09:16 AM
3rdGteg's Avatar
Default Re: motor mount inserts (AW)
I guess you don't have to replace cracked mounts if you're gonna have to cut them up anyways
Old Oct 13, 2002 | 10:27 AM
ragejed's Avatar
Only the upper drivers side mount you can cut and replace.
Old Oct 13, 2002 | 10:32 AM
3rdGteg's Avatar
So my pessenger and rear mount must be in good shape to use these inserts?
Old Oct 13, 2002 | 02:29 PM
ragejed's Avatar
Yes sir. Energy Suspension recommends only to use good mounts. And not to use broken ones.
Old Oct 13, 2002 | 05:05 PM
3rdGteg's Avatar
Old Oct 13, 2002 | 05:09 PM
ragejed's Avatar
lol
broke91hatch
Jul 24, 2008 12:48 PM
TypeRuz
May 20, 2004 05:55 PM
JUN JDM
Aug 4, 2003 01:28 AM
B94Cast
Nov 25, 2002 07:13 PM
IN VTEC
Oct 10, 2001 11:08 PM
