Which Motor Mount Inserts?
Old Jun 14, 2002 | 12:45 AM
comptechgsr's Avatar
Default Which Motor Mount Inserts?
which ones, and how easy are they to install?
thanks.
any improvements on launching/handling etc?
thanks
Old Jun 14, 2002 | 01:49 AM
ragejed's Avatar
Default Re: Which Motor Mount Inserts? (comptechgsr)
Search. As everyone has Energy suspension. Mine should be here today
Suspension.com has the best price. Very nice people.
Old Jun 14, 2002 | 01:55 AM
Default Re: Which Motor Mount Inserts? (ragejed)
good stuff, im checking out the page right now...
most of the pages i found when i searched dealt with pricing of mounts n where to get em?
besides that
how easy is the install and is aftermarket a lot better than oem?
thanks
Old Jun 14, 2002 | 07:55 AM
lazyguy's Avatar
energy suspension are great, they reduce wheel hop from a launch
Old Jun 14, 2002 | 09:00 AM
JDMCRVTEC's Avatar
i have the Prothane motor mount inserts, they are hard indestructable urethane. This would be the best bet if you are looking for inserts that will make not let your motor flex at all. The only problem is because the motor doesn't move at all from driving the car vibrates due to not have rubber or softer inserts to take the vibration. But if you don't mind the vibration, which is actaully not that bad you should get those, they would be the best for launching.
Old Jun 14, 2002 | 09:04 AM
Big Teggie's Avatar
Default Re: Which Motor Mount Inserts? (JDMCRVTEC)
Energy suspension inserts are great. I love mine, the motor stays planted.
Old Jun 14, 2002 | 02:07 PM
Default Re: Which Motor Mount Inserts? (Big Teggie)
how's the install guys?
does it come with instructions?
how long?
thankz in advance
Old Jun 14, 2002 | 02:17 PM
JDMCRVTEC's Avatar
the ones on the sides the main ones aren't that bad but the one inthe back like behind the tranny is a pain in the ***. the easiest way to chaneg it is to drop the tranny but, you don't have to its just a tight *** squeeze to do so, the easiest one is in the front, but other then that good luck.
Old Jun 14, 2002 | 02:42 PM
crap, can i jus get the ones for the sides?
i am a lil bitch
Old Jun 14, 2002 | 03:22 PM
Caffeine Slug's Avatar
you can't get just the sides, but they're cheap enough that you may as well just get the entire pack.
I did the install last week, and it was a pain. Front right took 20 minutes, front left took 2 hours (couldn't get it back on!), and the rear one took 4 hours.
vibration is pretty noticeable at idle, but it's fine above about 1k rpms. overall, I'm still happy with it.
airmaxbri
Oct 8, 2010 11:27 AM
no1_suspek
Honda Civic (2001 - 2005)
Sep 21, 2010 01:53 AM
TypeRuz
May 20, 2004 05:55 PM
intekragsr
Apr 1, 2003 09:31 PM
IN VTEC
Oct 10, 2001 11:08 PM
