motor
Old May 3, 2008 | 06:12 PM
thatdannyboy's Avatar
Default motor
I have a turbo b18b1 in four door gsr with hondata on street tune. I am hitting about 6 grand and It is like I slam on the brakes with out doing so plugs are new gaped right oil pres good and dist cap and rotar are not in perfect condition but looks good enough for proper contact.. Any suggestions on what that might be.. to describe it more its like engine comes to a hault at six grand only thing changed was i did the head gasket. Car idles fine and climbs good and holds boost..
Old May 4, 2008 | 02:35 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: motor (thatdannyboy)
Any cells? check your tps connection. maybe your injectors are clogged, or your starving on fuel, is it tuned or is it a preprogramed or chipped ecu?
Old May 4, 2008 | 06:38 AM
jhammond_82's Avatar
Reject Papi
Default Re: motor (wunfstgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wunfstgsr &raquo;</TD></TR><TR><TD CLASS="quote">Any cells? check your tps connection. maybe your injectors are clogged, or your starving on fuel, is it tuned or is it a preprogramed or chipped ecu?</TD></TR></TABLE> it could be any of those things.
Old May 4, 2008 | 02:16 PM
ubslow's Avatar
Default Re: motor (jhammond_82)
my money is on fuel cut
Old May 6, 2008 | 07:11 PM
Default Re: motor (ubslow)
sorry boost control vac line was off and hondata was shutting down the motor "overboost" thanks guys
greatnightmare
Aug 25, 2014 07:38 PM
hondaman177
10
Aug 2, 2007 10:06 AM
efyou
12
Apr 20, 2006 08:53 PM
salsero_utah
Nov 6, 2005 02:30 PM
dturbo
15
Aug 11, 2005 05:57 PM
