Is this more difficult???
Old Aug 3, 2005 | 02:13 PM
ka-nife_'s Avatar
Default Is this more difficult???
I own a 93 prelude VTEC & my right quarter panel is messed up real bad. I wanted to know if it is semi worth it to swap my engine versus fixing my quarter panel??? I found a 3rd gen integra shell for sale, I know people have swapped an h22 into a civic, but I wanted to know if an integra is easeir.
thanks
mike-dizzle
Old Aug 3, 2005 | 02:43 PM
projectTeG's Avatar
im pretty sure its the same, because both cars are bascally the same, id say it would be easier to swap into a teg because i think they have larger engine bays.
Old Aug 4, 2005 | 10:28 AM
ka-nife_'s Avatar
Default Re: (projectTeG)
That's what I was thinking
Old Aug 4, 2005 | 11:23 AM
Tweakmeister's Avatar
Default Re: Is this more difficult??? (93_pre-lewd)
H22 in an Integra is a pretty sweet setup from what I hear - the torque is great, and the weight difference can be tuned out with the proper suspension setup.
Go for it if you have the time
Old Aug 4, 2005 | 01:06 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
How much will it cost you to fix the Prelude?
It's not a 'direct' swap. For the H22 swap you will need axles and motor mounts costing over $1,000. The Prelude shifter does not fit in the stock Integra location, so you'll have to modify that as well.
Old Aug 4, 2005 | 01:10 PM
simon98h22's Avatar
Default Re: Is this more difficult??? (Tweakmeister)
Swap into a civic or an integra is virtually the same, both require some parts.
Off the top of my head?
- Aftermarket mounts
- You will probably lose AC (in the DC shell)
- You can salvage PS depending on your engine mount choice (you will also need a 97+ PS pump, you can re-use the main PS line from the DC)
- 90-93 Accord or 92-96 Lude midshaft (this will also affect which axles you need)
- 90-93 Accord or 92-96 shifter and assembly
- New exhaust pieces
- New axles (Wich ones depends on your midshaft selection)
- resistor box
- New rad hoses for the DC
- Various Honda nuts and bolts
Fitting the H22 shifter assembly will require you only to widen the hole in the DC, it's not hard. Make sure you put a tin shield under the hole after it's all together, it heats up the cabin something fierce.
Old Aug 10, 2005 | 03:37 AM
ka-nife_'s Avatar
Default Re: Is this more difficult??? (simon98h22)
Damn. That's a lot of work. It's exactly the same as doing a H22 into a civic that's in the tuner magazines. It's that when I bought my car I didn't check out the body to well just that the motor was money. My right 1/4 is full of mud & the other day I was backing into a spot @ my job & I hit the right 1/4 & now it's dented & cracked. My guys @ my body shop are going to help me out but I do have to pay them a little something. So just wanted to see if I had any other options w/ my engine.
Thanks for all the info guys. Maybe one day I'll do that swap.
MoonScryer
Jan 23, 2008 07:30 AM
mikey16556
Mar 26, 2004 09:46 PM
okaythen
Mar 20, 2004 07:53 AM
Chief Brody
Jan 30, 2004 01:12 PM
