missing in cylinder 1 problem help!!!
Old Feb 8, 2010 | 11:26 AM
gerbs94integra's Avatar
Default missing in cylinder 1 problem help!!! updated info!
hey guys,
i am having problems with my gsr. my check engine light came on the other day. and i had it checked out. it through some codes about it missing in cylinder 1. im not sure what to do. when the car is cold it runs bad. like it is missing in cylinder one. but when it is warm. it runs fine. i changed spark plugs. and got a induction cleaning system thing done the other day. i need help. because im not sure what to do.
what can i do if i am missing? what is there that i can do?
updated info!!!!
3/4/10
i just change the cap and rotor plugs and wires..
car is still running the same...
the car seems to hick up at about 3000 rpms...
im driving down the road and i shift into 2nd gear and i go kinda slow and the car bogs on me... like its not getting fuel...
my gas gauge isnt working it says the tank is always empty...
im not sure what is going on... does anyone have any suggestions?
Old Feb 8, 2010 | 11:50 AM
shiftmx179's Avatar
Default Re: missing in cylinder 1 problem help!!!
What did the spark plugs look like when you changed them, especially #1 cylinder? Check the plug wires, and the cap and rotor. What codes is it throwing exactly?
Old Feb 8, 2010 | 09:01 PM
sovada's Avatar
if its a cylinder one misfire it should be throwing a p0301
Old Feb 8, 2010 | 10:22 PM
ARdb8's Avatar
check yur spark plugs wires for any signs of arching (where ignition is grounding out on engine, quik spray with soapy water will do the trick) while the engines running. if that checks out, then do a compression check. if ok then you prob condemned an injector.
Old Feb 9, 2010 | 09:38 AM
thanks for the help guys. i just got new spark plugs. probly putting them in today.
Old Feb 9, 2010 | 01:20 PM
sovada's Avatar
no problem. but if you change the plug, wires, cap and rotor button and you still have the code, its possible you could have a clogged injector.
im not saying hey, go buy a brand new injector... it could just take a bottle of injector cleaner(preferably lucas) and run 93 through it as well.
Old Feb 9, 2010 | 02:27 PM
Jimmy's Avatar
Global Moderator
let us know how that goes..
Old Feb 9, 2010 | 02:47 PM
new spark plugs wires are in. cant really drive the car. snow is all over. we got a lot of snow last night...
Old Feb 9, 2010 | 02:50 PM
Jimmy's Avatar
Global Moderator
You should be able to start it up and see if it's misfiring/throwing a CEL, but yeah def wouldn't drive it in the snow
Old Feb 9, 2010 | 04:59 PM
Dave-ROR's Avatar
Valve adjustment recently? Badly out of spec valves will give misfire codes also.
Old Feb 9, 2010 | 06:18 PM
no... and i have every done that on any of my cars. where do u get that done at. how much does it cost?
how do u do that?
Old Feb 9, 2010 | 06:27 PM
Dave-ROR's Avatar
Well obviously a mechanic, or dealership, can do so. Otherwise, you'll need some time/patience, feeler gauges, preferably the snap-on tool for adjusting the valves themselves (there's a locknut and set screw you adjust). I'm sure there's a howto out there, it's not hard, but there's is a specific process. You should get the service manual if doing this work yourself. If you want, tell me what model Integra you have and I'll try to send you more info.
If you've never adjusted them they are likely loose as heck now, depending on how long you've owned the car. I generally check mine every 15k, at worse every 30k.
Old Feb 10, 2010 | 08:27 AM
ok. thanks for the info...
Old Feb 21, 2010 | 07:06 PM
i also just replaced the fuel pump... one of my honda friends said those go bad so i replaced that... but it is still running the same... my brother has some injectors i can have to replace mine... but i dont know if that will even help... i am still unsure what to do... help me out guys please
Old Feb 21, 2010 | 08:03 PM
superteg17's Avatar
so the car only has a misfire when it is cold??? how about under a load? (good amount of throttle in higher gear like 3rd?) is the po301 the only DTC stored?
Old Feb 21, 2010 | 09:22 PM
Bigmac88's Avatar
I doubt it's the injectors. Adjusting the valves might do the trick - that seems like your best bet. I also want to know how it reacts under load. Let us know :D
Old Feb 22, 2010 | 05:44 AM
how it reacts under a load...? not sure what u guys mean...
Old Mar 4, 2010 | 07:26 AM
changed the cap and rotor and plugs and wires now.... still doing the same thing tho....
Old Mar 4, 2010 | 10:52 AM
and i changed the fuel filter
Old Mar 4, 2010 | 12:06 PM
anyone?
Old Mar 4, 2010 | 12:21 PM
Jockone's Avatar
Under load like when you are on the gas going up a hill,you can get the same effect by standing on the brakes and trying to accelerate just in the parking lot or your driveway.
If it was a bad fuel pump it would not have been just 1 cylinder missing it would have been multiple cylinder missfire.
Could be badly adjusted valve as others have said or it could be a bad valve,read all your replies and follow what they are telling you,just chucking parts at it is going to get expensive in a hurry.
Old Mar 4, 2010 | 12:28 PM
upgrayedd's Avatar
if it stops missing after you get the rpms up, the chances are likely that you have a hole in a valve, thats what was wrong with my b20
Old Mar 7, 2010 | 02:25 PM
im going to get the valves checked out... thats sounds like a plan... thanks for all the help so far guys ill let u know how that goes...
one more question how much is it to get the valves adjusted?
Old Mar 10, 2010 | 11:06 AM
car seems to be running fine now... maybe it was something to do with the cold weather... but i dont know
SiBuddy00
16
Sep 10, 2015 01:59 AM
Wisdom Teeth
Mar 25, 2013 10:26 AM
sickntired
Jul 12, 2006 11:09 AM
screech
Apr 19, 2004 06:04 AM
bullz
Jul 15, 2002 10:19 PM
