misshift from 3rd to 2nd having problem
Old Nov 3, 2004 | 01:01 AM
lv6l's Avatar
Default misshift from 3rd to 2nd having problem
Modified by lv6l at 12:43 AM 6/13/2006
Old Nov 3, 2004 | 01:06 AM
yodas-gsr's Avatar
Default Re: misshift from 3rd to 2nd having problem (lv6l)
....your screwed...but its a great time to upgrade
seriously though, gotta go take it to a mechanic if you dont know how to do it and check that thing out. valves, piston... good luck man
late,
yoda
Old Nov 3, 2004 | 01:32 AM
integraboi8b's Avatar
ya man check compression you probably messed up some valves if your lucky.
Old Nov 3, 2004 | 01:49 AM
MR-MUGEN's Avatar
Default Re: (integraboi8b)
im saying valves
Old Nov 3, 2004 | 02:35 AM
lv6l's Avatar
Old Nov 3, 2004 | 05:37 AM
greaseball's Avatar
Default Re: (lv6l)
FERREA stainless get my vote.
Old Nov 3, 2004 | 09:40 AM
MR-MUGEN's Avatar
Default Re: (greaseball)
webb or skunk 2
Old Nov 3, 2004 | 10:04 AM
Invisible01GSR's Avatar
Default Re: (jdm92daintegra)
i have the same problem, but my idles at like 450, and drops a lot when i stop. i have no problems w/ my head. but im building mine so even if there is any problems,so it doesnt matter to me.
Old Nov 3, 2004 | 12:31 PM
boosted k20's Avatar
Default Re: (Invisible01GSR)
i would stay away from the skunk2 valves. i help out a friend in a shop and a few people have cracked those skunk2 valves.
hey invisible01GSR, did u try to raise ur idle speed? do that and it should fix ur problem. did u install cams in ur car, cuz usually when u install cams u might need to increase the idle speed screw on the throttle body. thats what i had to do
Old Nov 3, 2004 | 02:33 PM
lv6l's Avatar
Old Nov 3, 2004 | 03:00 PM
furious94ls's Avatar
Default Re: (lv6l)
You should of had em change that timing belt.
Old Nov 3, 2004 | 03:49 PM
totsie7944's Avatar
probably messed up a valve, and maybe blow smoe pistons.
Old Nov 3, 2004 | 07:18 PM
HONDA_TYPE_R's Avatar
Default Re: misshift from 3rd to 2nd having problem (totsie7944)
I had something similar happen to me...I went from the top of 2nd to 1st (went for 3rd). I locked up my differential and skidded down the road for a second. I ended up lucky...somehow one of the nuts on top of my valve lash adjuster had come loose, so I put it on and tightened it back up. I have pics on this link:https://honda-tech.com/zerothread?id=1042185
unix4linux
Oct 13, 2005 12:02 PM
Sinner
Aug 25, 2004 06:48 AM
99B16Si
Dec 11, 2003 11:45 PM
speedracer9k
Oct 13, 2003 06:32 AM
P1mpSlap
Jul 3, 2003 09:17 AM
