Is this method of testing the fuel pump acceptable?
Old Aug 14, 2003 | 11:32 PM
B18EG6's Avatar
Default Is this method of testing the fuel pump acceptable?
So I wanna test the fuel pump itself, and dont feel like taking the back seat out.
Can I just undo the service bolt on the fuel filter, then apply 12V at the main relay harness, the yellow wire with green stripe?
Old Aug 15, 2003 | 03:51 AM
DCStreetHtch's Avatar
Default Re: Is this method of testing the fuel pump acceptable? (B18EG6)
Yes, but its the messy way... just turn the key into accessory and you should be able to hear it start up. if you dont hear anything then its not working, in which its prolly the relay. If the pump starts up but you're getting no fuel than check your filter.
-Bryan-
BTW: Thanx for the tech signature idea for font color
Old Aug 15, 2003 | 08:24 AM
96IntegraLS4DR's Avatar
Default Re: Is this method of testing the fuel pump acceptable? (EGStreetHtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGStreetHtch &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but its the messy way... just turn the key into accessory and you should be able to hear it start up. if you dont hear anything then its not working, in which its prolly the relay. If the pump starts up but you're getting no fuel than check your filter.
-Bryan-
BTW: Thanx for the tech signature idea for font color</TD></TR></TABLE>
What you said is checking if fuel pump is working or not.
How do you check if fuel pump is degraded (ie not performing at its peak)?
nsone
May 14, 2009 04:35 AM
EG6KILIN
31
Apr 3, 2009 07:19 AM
djtheory
Oct 23, 2007 09:25 PM
lakehopper
Aug 11, 2005 05:12 AM
sm00thk0zz
Dec 13, 2004 08:53 AM
