maximum turbo boost
Old Dec 29, 2006 | 07:56 AM
VTEC_PRODUCTION's Avatar
Default maximum turbo boost
im planning on boosting my car...with a turbo...i want to know what is the maximum amount of boost you can put on a stock internal GSR engine...longevity is not an issue...the only thing i worry about is the aluminum block and the rings...also can anyone name off all the parts and send me reccomendations on all the parts i need?
Old Dec 29, 2006 | 08:01 AM
PrinceAli132's Avatar
Default Re: maximum turbo boost (Acura_Integra_Type_R)
Search!!! This has been covered plenty of times. Also check the forced induction section.
From what I have seen, stock internals have been capable of handling around 350whp.
A large turbo will require less psi to achieve the same power as a smaller turbo with more psi.
Make sure your motor is in good condition. Start off with a compression and leak down test.
Ali
Boots's Avatar
make sure your fuel is good and you get a really good tune and ive seen a gsr put 318 to the wheels on 12 pounds stock internals
Old Dec 29, 2006 | 08:04 AM
8YourV8's Avatar
Default Re: maximum turbo boost (boots)
see sig. 8.5 PSI stock internals, good tune. 340 whp.
edit: cobra/evo/STI/GT/G35/350z/s2000/ss camaro/LS1/454/502 eater. lol. the only close race was the STI.... but it was hooked up pretty nicely. im tellin you, ya cant expletive with a turbo vtec motor done up right.
gsrtpower
Jul 24, 2007 04:44 AM
99DC2GSR
Mar 14, 2007 12:37 PM
jfboy
May 28, 2005 09:44 AM
hondaboy92
Apr 16, 2005 07:39 AM
Madrat888
Jun 20, 2004 09:35 PM
