map sensor testing
Old Apr 21, 2015 | 03:45 PM
ThatOne02Accord's Avatar
Default map sensor testing
Having trouble diagnosing my 93 civic with a b18c swap.
When I unplug the map sensor on top of the throttle body, nothing changes. It still runs like crap. How can I test the map sensor with a multimeter?
When I got WOT it bogs down, backfires badly and almost stalls out. If I give it light throttle it will rev up but when you go WOT it bogs and almost dies until you let off the gas.
I replaced the TPS with a new sensor.
I get no change when I unplug the map sensor, I thinking I have a bad map sensor. I have a solid check engine light and can't pull codes. Solid check engine light on all 3 ECUs.
Old Apr 23, 2015 | 12:30 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: map sensor testing
How can you not pull the codes?????
Check the code!! see what it says! then come back and report.
did you recalibrate the new TPS sensor??
Old Apr 25, 2015 | 12:18 PM
Not sure, I jumped the service connector and the CEL just stays on solid, on all 3 ECUS.
I tried to test the old TPS sensor, got a good ground. When I tested the TPS it seemed to stay on 4.98 at the Closed and Open position, no change. Thought my TPS was bad, I bought a new one from Autozone. Still have the same result. I used a wire tracer to see if I had a break in the signal wire to the ECU but it seemed good.
I got the car going to a shop that specializes in Honda and Acuras. I'd be interesting to find out what the problem is. I've been scratching my head for months.
eg93LS
Jun 10, 2009 08:51 PM
SVOboy
Mar 26, 2006 11:48 AM
Soichiro-son
Aug 19, 2005 06:35 AM
kechup2eg6
Aug 10, 2005 07:47 PM
comptechgsr2000
May 8, 2002 03:53 PM
