map sensor problem!! HELP
Old Mar 17, 2010 | 05:59 PM
turboed rhd's Avatar
Default map sensor problem!! HELP
OK so ive been fighting with this map sensor CEL code for a while now...i have a obd2 gsr integra...cel is on and i check it and it is 3 flashes which is MAP and i also took it to autozone and they said it is #P0107...ive changed the map sensor 4 times and still throws the code and runs like *** at low rpm's and sometimes feels like its bogging out and flooding itself possibly at low rpms...please help
Old Mar 17, 2010 | 08:11 PM
SoTexDC2's Avatar
Default Re: map sensor problem!! HELP
Sounds like you may have the TPS and MAP sensor plugs reversed. They're exactly the same and can easily be installed backwards.
Are you trying random map sensors from peoples junk boxes, or did you buy a new one?
Old Mar 17, 2010 | 08:33 PM
slomofo's Avatar
GDD Member
Ummm, have you checked vacuum at the MAP hole? Could be something as simple as a bad throttle body gasket.
If he reversed the plugs, his idle would probably be surging and he'd most likely get a code for both sensors.
Old Mar 17, 2010 | 08:41 PM
SoTexDC2's Avatar
The one time I made that mistake, I didn't get any CEL at all.
Old Mar 17, 2010 | 08:47 PM
slomofo's Avatar
GDD Member
Okay, then
si_motor_spt
Sep 9, 2007 12:31 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
sakums20
Apr 29, 2004 02:40 PM
