Map sensor keeps failing...
Old Mar 15, 2007 | 10:56 AM
ekcivicphx's Avatar
Default Map sensor keeps failing...
I'm getting pissed now. This is the third map sensor that has failed in the last week. WTF. Any ideas what could be doing it? Did this happen to anyone else?
Oh and the symptoms are starts up fine and then dies...
Old Mar 15, 2007 | 09:37 PM
ekcivicphx's Avatar
Default Re: Map sensor keeps failing... (ekcivicphx)
Anyone?
Old Mar 15, 2007 | 09:39 PM
99Geeezer's Avatar
How are you determining the MAP is the problem?
Old Mar 16, 2007 | 05:39 PM
ekcivicphx's Avatar
Default Re: Map sensor keeps failing... (99Geeezer)
Basically, there's very few reasons why my car would start up and then die that fast with no spitting, sputtering, dieseling or anything. Just straight up shutting down. I've had a bit of experience with MAP sensors in the past and these are classic symptoms. Plus, after starting it with and without it plugged in, it did the same thing. Not to mention that after I replaced it each time, it would start and run just fine. I HATE DOING ELECTRICAL WORK, so if anyone has any other ideas, PLEASE let me know. hahahaha.
Old Mar 16, 2007 | 09:11 PM
suspendedHatch's Avatar
MAP sensors are very susceptible to damage from fuel and oil vapors.
Get a pressure gauge tester and measure the resistance of the sensors as per the helms manual to verify the sensors are bad.
Old Jun 16, 2007 | 04:27 PM
DC2TEGGA-GSR's Avatar
Default Re: Map sensor keeps failing... (suspendedHatch)
I had the same problem, and its actually a pretty dangerous one, sometimes i wouldnt throw the code until i was actually driving and the car would die, most of the time crossing traffic. andways i checked all the vaccum lines and the entire wiring harness and didnt find anything suspicous. i thought i would have to buy a new clip but i tried this first and it worked. I unplugged the three clips to my ecu for 15 sec. and tried it out. i got 4 complete cranks with no problem, no cel. i test drove it and went all the way the gears to make sure it wouldnt die, stopped, cranked again and drove back, pushing the car hard to make sure it wasnt going to fail under any driving condition. So far, so good. give it a shot.
Old Jun 16, 2007 | 05:19 PM
Dogginator's Avatar
Daisy... Daisy...
Have you checked the IACV? Will the car run if you apply throttle?
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
spockeg
22
Oct 19, 2009 07:54 PM
alfee
Aug 16, 2006 01:07 PM
Chubz
Honda S2000
Jun 11, 2005 04:52 AM
CiViC SiR
Jul 7, 2003 02:55 PM
