manual conversion on obd2b???
Old Apr 5, 2004 | 11:12 AM
silver00teg's Avatar
Default manual conversion on obd2b???
i know everything i need to do on the conversion but i know that 00-01's came with the key immobilizer i was wondering if i could use a 00 ls ecu for my car and everything would still work btw my car is a 2000 thanks for the help
Old Apr 5, 2004 | 11:13 AM
Audi A4's Avatar
Default Re: manual conversion on obd2b??? (silver00teg)
I dont see why not
Old Apr 5, 2004 | 11:27 AM
01DC-2's Avatar
if that LS ecu has a immobilizer on it you cant use that ecu(unless its the same key). unless u disable it or just get a chipped one. i have a 01gsr i took the ecu off and am now using a hondata/erics racing, its a P28 but the connectors where converted to a OBD2b.
i believe it has to be the same key that came with the ecu.
i think thats right.. someone correct me if i am wrong.
Old Apr 5, 2004 | 11:40 AM
Default Re: manual conversion on obd2b??? (01DC-2)
i dont think the one im getting has a immobilizer cause the guy im getting it from was using it in his 99 civic
Old Apr 5, 2004 | 11:56 AM
01DC-2's Avatar
should work then if he is using it on his civic
try it b4 u buy it
-good luck
Old Apr 5, 2004 | 12:07 PM
xplanetearth420x's Avatar
i think it will work
Old Apr 5, 2004 | 12:12 PM
Default Re: manual conversion on obd2b??? (xplanetearth420x)
the problem is i havent converted my car yet would i still be able to put it in and see if it works?
Old Apr 5, 2004 | 12:13 PM
01DC-2's Avatar
yes.. just plug it in and see if the car starts up..
you cant go wrong each connector is shaped different
Old Apr 5, 2004 | 12:14 PM
cool thanks for the help guys
Old Apr 6, 2004 | 12:07 PM
ok the ecu does have a immobilizer but i did some research and found out that i can get the key reprogrammed for the ecu or just get it removed all together by taking it out of the ecu my question is could i take the one from my factory ecu and put it in the new one
thanks for the help
I CRX I
Engine Management and Tuning
Feb 18, 2010 08:09 PM
4thgenx42
Jan 4, 2007 05:34 AM
jakedoza
Oct 4, 2006 04:32 PM
bigfatchien
Jun 25, 2004 09:02 AM
integranator
Aug 7, 2003 12:40 PM
