manual to auto
Kind of depends on how far you want to go, it's easier to just extend the leads, yellow or yellow/red, [input] and the green/white, [output] from the Automatic Gear Position Switch plug and run them to the back-up light switch on the 5 speed. you will also need to at least install a jumper on the in and out start leads, black/white. or if you want, install a relay, [starter relay] between them and install a CIS, [clutch interlock switch] to trigger the relay. 94
travbrack
Aug 3, 2010 03:17 PM
