manit. req. light 01 integra
Old Jun 28, 2004 | 07:51 AM
JAI-DM's Avatar
Default manit. req. light 01 integra
Im sure this has been beaten to death but I searched and didnt find the correct answer. My 2001 integra ls just started blinking the manit. req. light this morning ten times after car is turned on. I cant seem to find the reset button under the colum anywhere, actually its not under the colum at all. Anyone know where it is?
thanx
jai
Old Jun 28, 2004 | 07:57 AM
SuzukaBlueAP2's Avatar
Default Re: manit. req. light 01 integra (INTEGRAJAI)
Did you crawl under the steering column and look? That's where it is located...on the underside of the steering column.
Old Jun 28, 2004 | 08:10 AM
JAI-DM's Avatar
Ya I totally looked there, all i see is a sticker that says "obd connector on pass side of console" Im clueless, there are only holes for the screw holes and column monut bolt holes
Old Jun 28, 2004 | 08:16 AM
JimBlake's Avatar
Default Re: (INTEGRAJAI)
Under the DASHBOARD, just behind the bottom edge of the dash, roughly above your right knee. The button faces towards the gas pedal.
Or better yet, since mine's a '95... Did some newer Integras go to the system where you press the odometer reset button while turning on the car?
Old Jun 28, 2004 | 08:28 AM
BlackThorN's Avatar
http://www.c-speedracing.com/faq/01.php
took me one second to search
https://honda-tech.com/zerosearch
type in "reset light" in archived there are 923947293472937423420394 topics on it practically
plus it's in the owners manual also
Old Jun 28, 2004 | 10:00 AM
G-bonic's Avatar
Hijacked
If u really done wit ur maintenance just reset it, like wut they just do at the dealership they just reset it and charge u some $$$.. but anyways just turn on ur ignition and then locate the button underneath ur steering wheel and hold it for 15 to 20 seconds and thats it u all set... it will go bye bye.....
Old Jun 28, 2004 | 10:02 AM
Kendall's Avatar
Why not just pull the cluster and remove the bulb, you'll never have to worry about it again.
Old Jun 28, 2004 | 12:16 PM
LSVTEC DC2's Avatar
Default Re: (JimBlake)
u r right Jim Blake it's under your right knee... if u look under your dash on the driverside you'll see a green button to push.. it's the same for all 94-01 integras
Old Jun 28, 2004 | 02:19 PM
VsR785's Avatar
im having the same problem, and its not under my right knee either.....
Old Jun 28, 2004 | 02:24 PM
timmy8151's Avatar
Default Re: manit. req. light 01 integra (VsR785)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VsR785 &raquo;</TD></TR><TR><TD CLASS="quote">im having the same problem, and its not under my right knee either.....</TD></TR></TABLE>
Look harder. If you run your hand under the dashboard you should feel it.
Old Jun 28, 2004 | 02:44 PM
VsR785's Avatar
Default Re: manit. req. light 01 integra (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
Look harder. If you run your hand under the dashboard you should feel it.</TD></TR></TABLE>
already looked under there and its not there, i used to own a 94 ls and yeah it was easily found. but now i own a 2001 gsr and cannot find it...
Old Jun 28, 2004 | 03:28 PM
laseca's Avatar
Here's a picture of the underside of my dash on my '01 GSR. Position your hand directly below the steering column and feel the panel until it ends. Move your hand slightly to the right and you'll feel a plastic box. That box has a square button on it. You hold that button down for about 10 seconds while turning on your ignition on and that will clear it. If you don't have this box, it was either removed or relocated by someone else (if you're not the original owner). If you bought it new, it has to be there.
Old Jun 28, 2004 | 04:35 PM
VsR785's Avatar
Default Re: manit. req. light 01 integra (laseca)
thanks
Old Jun 28, 2004 | 09:59 PM
aeon's Avatar
yeah, mines had a green button. i guess it's different in different years models
Aqualite_Solid
Feb 6, 2011 09:01 AM
Mr. Softee
Nov 2, 2010 10:38 AM
Ruben19
Sep 19, 2006 04:55 AM
95_Honda_Civic
Jun 13, 2003 03:19 PM
wu tang
Sep 20, 2002 07:40 AM
