Major problem with b20
Old Dec 19, 2006 | 06:02 PM
B204door's Avatar
Default Major problem with b20
Ok at first i thought it just needed new conecting rods or even a valve adjustment but i think i was wrong. The head is making a really loud clicking noise wen the car is running. I took the spark plugs out one by one and turned the car on cuz sum1 told me to do so to see if the rods are nocking and he sed if the sound goes a way its a rod nock. the sound didnt go away but i found a lot of oil on the 3rd spark plug from the left and wen i took that one out the sound was louder. Also i noticed a little oil was coming out of the butom of the valve cover . I'm really upset and i dont want to swap to another motor. What do u guys think this is please help!?!?!?
Old Dec 20, 2006 | 06:13 AM
B204door's Avatar
Default Re: Major problem with b20 (B204door)
bump ppl help me
Old Dec 20, 2006 | 07:30 AM
Sam92Teg's Avatar
Oil on the spark plugs near the plug wires is caused by worn tube seals that fit under the valve cover. Sounds like you also need a valve cover gasket. Don't panic yet, you might just need a valve adjustment to quiet the valve train down.
So while your replacing your tube seals and valve cover gasket(might as well buy a valve cover gasket set which should include tube seals) you can adjust your valves and your noise will probably go away. Get some new NGK V-power spark plugs if you need them while your at it ($1.95 each) which are OEM but can be purchased at any parts store cheaper.
Old Dec 20, 2006 | 11:21 AM
B204door's Avatar
Default Re: Major problem with b20 (Sam92Teg)
ALright thanx. I guess am gona try that and see wat hapens i have no other choice. I just dont wana replace the motor it has under 50k on it i dont wana let it go to waist. If sumbudy on here wants to sell theirs that would help me but anyway thanx a lot man
Old Dec 23, 2006 | 09:57 PM
vtec_bangeR's Avatar
dang my car is doing the same thing. THAT noise is hella annoying. kinda of scary when you think about it i gotta pull out my spark plug wires and see if the car stutters or not. sounds like somthing broke in my car -_-"
Old Dec 26, 2006 | 07:31 PM
B204door's Avatar
Default Re: (hobo_x)
hell yea man i dont even drive my car now i dont wana expletive it up more than it is. I gota b18 head and im gona put that one on i think its my valves but expletive it i dont wana buy new ones and that not b it so im jus gona change heads. good luck man and be careful wen driving
Old Dec 27, 2006 | 06:10 AM
haha yeah man, right back at you.
Old Dec 28, 2006 | 07:55 PM
B204door's Avatar
yo, it wasnt a valve adjustment, gotem checked dint do **** i def. gota bent valve or sumthin...
Old Dec 29, 2006 | 12:50 PM
most likely it is. sux azz i just put some new valves 2 months ago. lol
Old Dec 30, 2006 | 12:10 AM
B204door's Avatar
ooo dam, do u think u have bent valves 2 or did u figure out wat hapened with urs?
Moo Sid
Oct 30, 2017 09:26 AM
standbackimapro
Apr 29, 2006 05:38 PM
Hey Whats Up
May 5, 2005 04:46 PM
Spec R
Jan 15, 2005 06:28 AM
CalvitoSol
Jul 8, 2002 12:03 AM
