MAF sensor
Old Oct 6, 2024 | 03:23 PM
Marcio Escobar's Avatar
Default MAF sensor
Hello everybody, I have a question do Acura Integras have a MAF sensor? Or what regulates the entry of air in the motor? This question its because I have an Issue with my Integra 99 that when I want to give it more power, start like farting and losing power, and when I tried to go on a climb, car losses power or didn't end going up, any tip?
Old Oct 6, 2024 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: MAF sensor
The factory engine does NOT utilize a MAF sensor... only a MAP sensor.
Old Oct 6, 2024 | 11:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yes, it has a MAP sensor, its located on the throttle body.
Also check your Ignition timing with a timing light and make sure its within specs sounds like you have a misfire check for codes in the ECU with a scanner tool.
_Shadow_
Apr 14, 2002 06:21 PM
