lugnuts
Old Jun 4, 2009 | 12:55 PM
JL_DC2's Avatar
Default lugnuts
hey guys, i'm new to the car scen, i just got a set of rota circuits 10 from a friend without lugnuts, the question is can i use my stock lugnuts on those wheels or i have to buy a new set? thanks
Old Jun 4, 2009 | 12:59 PM
jdm_bones's Avatar
Default Re: lugnuts
Your used stock lugnuts will work...There is no reason, why they shouldn't.
Old Jun 4, 2009 | 01:44 PM
Phat_97_LS's Avatar
Default Re: lugnuts
Dont use stock lug nuts with aftermarket rims.
Heres why > https://honda-tech.com/forums/wheel-tire-56/9658-forum-rules-faq-read-before-posting-1188922/
Old Jun 4, 2009 | 01:53 PM
TunerN00b's Avatar
Default Re: lugnuts
Heres why > https://honda-tech.com/forums/showthread.php?t=1188922
Correct!
The seats are different, resulting in a significantly smaller contact area, making it unsafe. That is a huge reason why it shouldn't work.
Old Jun 4, 2009 | 01:55 PM
jdm_bones's Avatar
Default Re: lugnuts
Dude what are you talking about, He's fine.... He has a stock wheel set up with aftermarket wheels, his stock lug nut are fine on his stock wheel studs...Just make sure you tighten them up to 80 foot pounds, in a X pattern while the car sits on the ground.
Old Jun 4, 2009 | 01:59 PM
99civicsiguy's Avatar
Default Re: lugnuts
just buy some locking aftermaket lug nuts
Old Jun 4, 2009 | 02:01 PM
1200 Hobos's Avatar
Default Re: lugnuts
.... He has a stock wheel set up with aftermarket wheels...
NO MAKE SENSE! Studs have nothing to do with it, it's about the shape of the seat on the lug nut.
Don't use oem ball seat lug nuts with aftermarket wheels. Aftermarket wheels need a conical seat lug nut to properly torque or else they will loosen up under extreme heat.
Old Jun 4, 2009 | 02:23 PM
TunerN00b's Avatar
Default Re: lugnuts
Doesn't always take extreme heat either.
I torqued down a set of aftermarket lugs on a set of OEM GSR Blades @ 75 ft-lbs (forgot my damn OEM lugs), went through tech, drove 4 blocks to Jack in the Box and back, put the car in grid, and noticed 6 of 16 lug nuts were loose while checking tire pressures... Cursed, a lot, and then put the crappy street tires back on (aftermarket wheels) so I could run that day with the nuts I did have.
Old Jun 4, 2009 | 02:32 PM
1200 Hobos's Avatar
Default Re: lugnuts
True
I had stockies on my Weds, after a session at buttonwillow I went to recheck the torque and several of them had loosened themselves by a full turn! I was lucky. The ball seat lug nuts on aftermarket wheels seem to be ok with everyday driving. I still woudn't recommend them since they chew up wheels from improper fitment.
Old Jun 4, 2009 | 03:06 PM
Targa250R's Avatar
be professional
Default Re: lugnuts
Wrong.
All Honda OE wheels use a ball seat for the lug nuts. Most aftermarket wheels use a tapered (conical) seat.
You cannot use ball-seat lugs on taper-seat wheels, and vice versa. The contact area is reduced and the lugs tend to loosen themselves and back off the studs, which can potentially cause the studs to shear off and the wheel to become detached from the car. Good luck with that.
You also have to be careful with taper-seat lugs as some wheels require a 45-degree taper while most require a 60-degree taper.
Old Jun 4, 2009 | 08:58 PM
jasoncanseeoh's Avatar
Default Re: lugnuts
WHAT DOES THAT HAVE TO DO WITH ANYTHING!?
Old Jun 5, 2009 | 05:08 AM
JL_DC2's Avatar
Default Re: lugnuts
ok thanks all, i got an idea what to do now.
JKGONZALEZ3
Nov 28, 2006 09:15 AM
cre18
46
Dec 4, 2005 06:35 AM
kcjohnnyboy
Nov 9, 2003 03:24 PM
B18Redline
Aug 16, 2003 07:26 PM
moondoggy
May 15, 2003 12:18 AM
