LSVTEC COMPRESSION #'s and plug pics
Old Oct 15, 2013 | 05:22 PM
TUR3Ovtec's Avatar
Default LSVTEC COMPRESSION #'s and plug pics
OK, so I started noticing that I'm going through oil pretty quickly. Decided to do a compression test. I took off the injector clips and wires off and hooked up the tester and just let it crank till the needle stopped moving. Im running a stock obd1 p72 gsr motor, stock intake manifold, throttle body , headers, everything is stock except an intake Check out the pictures of spark plugs and my numbers and tell me what you think please. #'s were 180,165,175,190
Old Oct 15, 2013 | 05:28 PM
ricetastic's Avatar
Default Re: LSVTEC COMPRESSION #'s and plug pics
how many miles are on it? i would do a leakdown on the 165 psi cyl.. prolly just wornout and tired..
Old Oct 15, 2013 | 05:29 PM
ricetastic's Avatar
the number 3 pictured spark plug looks like oil contamination and build up
Old Oct 15, 2013 | 05:35 PM
TUR3Ovtec's Avatar
I only have probably 2000 miles on with the lsvtec. yeah 3rd one was the worst.... what could it be? Or is it nothing to worry about? I'm going to google how to do the leakdown test... Also this was done with the motor cold and not WOT.
Old Oct 15, 2013 | 05:36 PM
B_Swapped93's Avatar
Under 200psi and you'll start to feel it...240+ is ideal for a healthy engine. I'm guessing it runs a bit rich judging by the outer edge of the plug.
Old Oct 15, 2013 | 05:40 PM
TUR3Ovtec's Avatar
yeah well I was thinking it was running rich because I never got the ecu tuned after doing the swap and when I floor the car I see a cloud of smoke and it smells. Also, I bought a P72 off ebay and don't remember if the guy put his own "default" tune.
Old Oct 15, 2013 | 05:41 PM
TUR3Ovtec's Avatar
So, since mines has lower than 200 anything i have to do??? i cant tell from looking at the picture chart of sparkplugs to see if mines are nothing to worry about or not.
Old Oct 15, 2013 | 05:59 PM
do a wet compression test white smoke on hard acceleration would make me say piston rings(wet test to determine). try getting a chipped ecu for your set up instead of some guys attempt to tune his own car.
Old Oct 15, 2013 | 06:14 PM
TUR3Ovtec's Avatar
To be honest I don't know what color it is but if I had a guess from how many times I saw it I would say black. I only notice it at night time if someone is behind me and I decide to floor it and look at my side view mirrors then see smoke coming out.
Old Oct 15, 2013 | 06:15 PM
TUR3Ovtec's Avatar
the wet test is putting a teaspoon of motor oil right and see if it does anything to the numbers?
Old Oct 15, 2013 | 06:23 PM
^yup
too hard to make a call in the night if you can have someone drive the car for you and follow and see how black the exhaust is when they floor it.
Old Oct 15, 2013 | 06:34 PM
TUR3Ovtec's Avatar
true i'll probably try that out tomorrow. How much would the numbers jump by?
So as far as the plugs though they are burning good but just a buildup like im running rich right?
Old Oct 15, 2013 | 06:42 PM
Can't say...if it's over 20psi of a jump you've got problems. yes or burning/leaking some oil.
Old Oct 15, 2013 | 06:50 PM
TUR3Ovtec's Avatar
gotcha, i will let you know tomorrow... gonna sound dumb but just pour the teaspoon of any w30 in the part where the spark plug goes and put the compression tester in right?
Old Oct 15, 2013 | 06:52 PM
Yup^
don't be alarmed if it stumbles on first start up. Unplug the dizzy, just incase you didn't on the first go wouldn't want to fry your coil.
Old Oct 15, 2013 | 06:55 PM
TUR3Ovtec's Avatar
Yeah I did I pulled off all wires.... And should I do this hot or cold
Old Oct 15, 2013 | 06:56 PM
Hot and wide open throttle
Old Oct 15, 2013 | 07:10 PM
TUR3Ovtec's Avatar
Ok cool I'm going to do it first thing in the morning
Old Oct 16, 2013 | 09:16 AM
TUR3Ovtec's Avatar
Ok I had a buddy drive my car little bit of white smoke but when he shifted cloud of it
Old Oct 16, 2013 | 09:18 AM
halfakneegrow's Avatar
Sounds like you washed the rings out. Never put an unknown ecu on a motor you put together. Also tune the motor right away so you don't take the chance of running in the motor lean (detonate) or too rich (washing rings out).
Old Oct 16, 2013 | 10:00 AM
TUR3Ovtec's Avatar
It's not the headgasket is it
Old Oct 16, 2013 | 10:44 AM
no^
just a shitty "tune" what were the wet test numbers ?
Old Oct 16, 2013 | 11:15 AM
TUR3Ovtec's Avatar
We are about to do it now give me like 20 minutes.... I hope it's not the headgasket or the piston rings... I don't wanna take te motor out the car :-/
Old Oct 16, 2013 | 01:13 PM
HG is super easy to replace lol piston rings....yah not so much it involves ripping the block apart and then once you're done honing and re-ring gotta check all those clearances. Big PITA
Old Oct 16, 2013 | 01:33 PM
TUR3Ovtec's Avatar
Ok so we didn't do a wet test because we used his gauge at the shop once hot and another cold and got numbers same on all cylinders both times
210 200 200 205. He says it might be the valve stem seals which I had changed when I sent the head to the machine shop
